erica b
1950 avalon
Post by erica b on Sept 28, 2017 13:59:34 GMT -8
Finally grabbed some tools and got started. Woo. Rot rot rot. I was able to get the front unattached. Got started on the from window, which appears to be riveted instead of screwed. I'll tackle that tomorrow. !
Post by mrmarty51 on Sept 28, 2017 15:48:42 GMT -8
YUP, thats what they look like after that many years.
Post by vikx on Sept 28, 2017 20:35:54 GMT -8
Probably Dreaded Twisty Nails instead of rivets. They are a real pain to remove with out dents and damage.
erica b
1950 avalon
Post by erica b on Sept 29, 2017 9:02:23 GMT -8
Probably Dreaded Twisty Nails instead of rivets. They are a real pain to remove with out dents and damage. Thanks! Makes sense. Do you think they could have been used to attach a window? They are just along the top. I have removed a few of them but in the rotten section and they were much smaller.
Post by vikx on Sept 29, 2017 10:42:48 GMT -8
Yes older trailers often have twisties everywhere. My 57 Shasta has the door installed with them. Ugh.
Post by mrmarty51 on Sept 29, 2017 15:45:43 GMT -8
Go to the parts store, or Snap On tool truck, tell them You want one of those wood handle heavy duty scrapers. When You get the scraper, grind the wood away from the butt end of the handle, leaving a good portion of the steel shank exposed. If You dont do that the wood handles will split. then You can use the scraper like a thin chisel, place it between the two layers and strike the end of the steel shank with a hammer. That will start the twisty nails out, then You can use a claw type nail puller and finish them off. Using this method will decrease the possibility of creating a lot of damage.
erica b
1950 avalon
Post by erica b on Sept 30, 2017 14:49:04 GMT -8
Thank you!
erica b
1950 avalon
Post by erica b on Sept 30, 2017 18:24:06 GMT -8
Post by mrmarty51 on Sept 30, 2017 21:21:17 GMT -8
oH Heck, thats not so bad. It needs a restoration job, but I dont see where there is huge chunks of rotted wood that has, or is falling out.
Post by vikx on Sept 30, 2017 21:52:16 GMT -8
Could be worse...
erica b
1950 avalon
Post by erica b on Sept 30, 2017 22:43:01 GMT -8
oH Heck, thats not so bad. It needs a restoration job, but I dont see where there is huge chunks of rotted wood that has, or is falling out. Where the nails are, on the right, that's the non existent front curbside support. Tomorrow we'll get the front window out and I'll report again! Thanks guys!
erica b
1950 avalon
Post by erica b on Oct 1, 2017 0:09:24 GMT -8
erica b
1950 avalon
Post by erica b on Oct 1, 2017 11:26:33 GMT -8
So it seems the wood that disenegrated is plywood. It's between the frame and the skin.
Post by kirkadie on Oct 1, 2017 12:19:52 GMT -8
Don't go too far without paper and pencil drawings and measurements to go along with copious photos. Especially if you plan to reuse old skin. These drawings will help you to remember exactly where wires etc need to be to fit original access holes... ask me how I know that. I'm doing a mix of original sides and new front top and back and am jumping hoops for lack of that drawing. And save everything you remove until you've replaced it with new.
erica b
1950 avalon
Post by erica b on Oct 1, 2017 12:58:03 GMT -8
Don't go too far without paper and pencil drawings and measurements to go along with copious photos. Especially if you plan to reuse old skin. These drawings will help you to remember exactly where wires etc need to be to fit original access holes... ask me how I know that. I'm doing a mix of original sides and new front top and back and am jumping hoops for lack of that drawing. And save everything you remove until you've replaced it with new. Thank you. I'm taking pictures but I love the idea to sketch too.
