tdecell
1969 Aristocrat Lo-Liner
Post by tdecell on Sept 20, 2017 8:58:00 GMT -8
I have torn the 1969 Aristocrat down and I'm in the process of replacing the floor. Before and during the teardown, I took over 350 pictures (so far) and wrote down innumerable measurements. Except for 1 apparently... I did not record the length of the floor from the step up towards the rear to the very back edge of the plywood flooring. I do have a picture that I think I can get possibly come up with an approximate measurement from.. But if there is anyone out there that could measure from the forward most edge of the rear bumper to the rear edge of the lower wall trim (under the baggage compartment door), that would be a great help! Thanks in advance.
Post by vikx on Sept 20, 2017 21:50:34 GMT -8
From my photos, I'm thinking the lowest board is 3 1/2". The metal belly is on the frame, so that adds a little more than 1/16" with spacing, etc. Since the whole back is apart, you do have the option of moving the cargo door a bit.
When using the old skins, you can position the cargo exactly. Tack them in place using old screw and staple holes, then tack the back. You'll know how to position the cargo. The sides may need to be almost done before you can position the back skin.
The trailer will tell you what to do.
