roadtripper
Post by roadtripper on Aug 19, 2017 19:25:09 GMT -8
All original elect was 110v and I'm changing to all 12volt. The stove hood vent then has a 110v fan motor. Any suggestions on the best place to find a 12v motor to replace it that would fit ok? Also have an old garage sale find 50's era small table top fan that was 110 and it died. Then I thought this would be great in the trailer. So same question...where to find a 12v motor? Thanks.
Post by vikx on Aug 19, 2017 21:51:25 GMT -8
The stove vent fan is easy; just go to an RV place and ask for a 12 volt replacement for the hood.
I recommend that you at least install some 110 outlets in your trailer. A 110 INlet is very reasonable in cost and having an outlet or two will allow you to operate a lamp or fan.
Another option is an inverter. It uses battery power to operate 110 items. The battery(s) can drain very quickly, but it is another way to go..
