haze5736
1970 Fan Lee Liner 16'
Post by haze5736 on Aug 17, 2017 14:31:48 GMT -8
I need to replace the tongue jack on my camper. I got the 3 screws out no problem but it still won't budge. Is it welded to the plate under the tongue or is mine just badly corroded? It all looks like one piece to me, the tube and the plate that connects to the frame.
Post by vikx on Aug 17, 2017 20:58:32 GMT -8
Should come right out but might be rusted in place. Take a look for tack welds, a PO may have messed around.
haze5736
Post by haze5736 on Aug 19, 2017 1:10:09 GMT -8
It was rusted in place. It really looked like the tube and bottom plate were one piece. Lots of grinding and I finally removed enough rust to beat it out from the bottom. That was way more work than it ought to be. My new 2000# jack is on its way from VTS.
Post by mrmarty51 on Aug 19, 2017 12:37:16 GMT -8
Sometimes rust will hold better than a lot of welds I have seen. LOLOLOL
jan
1954 Terry Cub
Post by jan on Oct 24, 2017 17:45:28 GMT -8
Post by mrmarty51 on Oct 24, 2017 19:06:38 GMT -8
That is one strange looking little jack. If there is enough room a hole saw could be used to drill through the top plate then a regular trailer tongue jack can be used. Anoter option would be to get one of the trailer jacks that pivots to horizontal when not in use. those are welded or clamped to the side of the trailers tongue Just need enough room so that they can be released then pivoted.
Post by vikx on Oct 24, 2017 21:10:56 GMT -8
datac
1957 Cardinal
Post by datac on Oct 25, 2017 15:13:19 GMT -8
Gotta ask the obvious- are you using a wheel with that jack? It's not uncommon for older jacks to be a bit short without one. If you'd prefer not to use a wheel, years ago I used to use the base of a cheapie Harbor Freight stamped steel jack stand, inner diameter was a perfect fit for the jack tube and gave nearly a foot of lift.
jan
1954 Terry Cub
Post by jan on Oct 25, 2017 19:40:23 GMT -8
datac
1957 Cardinal
Post by datac on Oct 25, 2017 20:58:55 GMT -8
That's the whole jack and wheel- you may be able to use your existing jack with just a clip-on wheel, like this: www.amazon.com/gp/product/B0050NGB6O/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1You'll need to check the tube diameter to make certain you find one that's a good fit. Most older trailer jacks were originally equipped with wheels, long lost. They either get busted off on a bump when folks forget to remove them before towing, or they remove them and lose them. If your jack has a square or rectangular shaft, your snazzy red jack stand may work fine (and finding a wheel to fit will be a problem anyway). If it doesn't fit your jack stand, you might try one like this, remove the center post, and either use the provided lock pin or a bolt through the lock pin hole to support the shaft:
jan
1954 Terry Cub
Post by jan on Oct 25, 2017 22:28:39 GMT -8
Great! Even I understand that!
datac
1957 Cardinal
Post by datac on Oct 26, 2017 8:36:34 GMT -8
By the way, that's a great looking jack. If it were mine, I'd do everything I could to keep rather than replace it.
Post by mrmarty51 on Oct 26, 2017 10:24:58 GMT -8
Yeah, long as it cranks up and down okay and will support the weight. as suggested, just put on a wheel or an extension.
jan
1954 Terry Cub
Post by jan on Oct 26, 2017 20:54:39 GMT -8
I'm going to try a wheel; will post a picture after next week; I'm going to visit my 2 year old grandson!
jan
1954 Terry Cub
Post by jan on Nov 8, 2017 16:22:34 GMT -8
I've ALMOST got the jack on, but it did NOT help that the instructions had the bolts going backwards of the way they were supposed to!!! Pix of the diagram, jack from above and head on are here: www.facebook.com/photo.php?fbid=10156044884035572&set=pcb.10156044895715572&type=3&theaterpix on FBOK, Of course, anyone with a more spatial/mechanical brain than mine (which is almost the entire universe) would have figured it out without a diagram. I have the top bolts fixed, but Pac NW rain encouraged me to procrastinate finishing until tomorrow. BTW, the remnants of the jack built into my trailer were modified to hold the propane tanks and using other installation methods without welding were not going to work. (My 92 year old Dad helped weld ships at the Kaiser Shipyards during the war, but I don't want him welding with his current eyesight, etc.)
