theresa
Post by theresa on Aug 15, 2017 7:06:02 GMT -8
What do you all use? On my Shasta Airflyte, there is about a 6" high piece of laminate/Formica that matches the counter and the table. When I removed it 2 years ago, I didn't pay attention to what went between it and the counter top surface. What do you all use for trim in the 90 degree corner between your counter and backsplash?
roadtripper
Post by roadtripper on Aug 15, 2017 9:52:28 GMT -8
Mine has a trim with a small cove on top and enough flange below to nail to back of counter top plywood. I think this is kind of normal and I think this aluminimum trim style is available out there somewhere. Can't remember where i saw it.
Post by danrhodes on Aug 15, 2017 12:24:10 GMT -8
Mine originally used white cove gimp. When attached to the back of the counter, it makes a nice smooth fillet, like a good caulk job. We used black as it had a nicer match to the counter color. www.vintagetrailersupply.com/3-4-Cove-Gimp-p/vts-012.htmI don't have a good closeup, but you can see it around the edge of the counter and wall here.
theresa
Post by theresa on Aug 15, 2017 18:29:14 GMT -8
thanks danrhodes and roadtripper ... another question along the same line or area at least... I think I made a mistake when I made my countertop and I didn't extend it beyond my cabinet base. So it's flush all the way around. How does the aluminum trim go on the counter? Is it just a right angle the covers the top and front and nails on? Or is it supposed to go around the top, front and bottom? I really thought I was paying attention to all these details when I removed stuff, but clearly not!
Post by danrhodes on Aug 15, 2017 18:34:14 GMT -8
The stuff I used would work fine with a flush counter install. It might actually work better since mine hangs over the 5/8" counter edge. 1/4 in. x 15/16 in. x 96 in. Metal Mira Lustre Grooved Edging Moulding www.homedepot.com/p/205576705
Post by mel on Aug 16, 2017 4:29:45 GMT -8
Post by mel on Aug 16, 2017 4:41:07 GMT -8
danrhodes, I would love to see a close up of your corner with that gimp, and how do you use that one, I guess I dont understand the install of that one
Post by danrhodes on Aug 16, 2017 7:38:34 GMT -8
danrhodes, I would love to see a close up of your corner with that gimp, and how do you use that one, I guess I dont understand the install of that one It staples to the back like regular gimp. When installed tightly, the flap forms a nice curve. Some campers even used in place of the tubular gimp, but mine only used on the counter. I don't like gimp on the floor because it's hard to clean, but I think I might consider this next time for a clean look. (Forgive the dirty counter... Never cleaned up after last trip)
theresa
Post by theresa on Aug 16, 2017 8:03:50 GMT -8
I do like that danrhodes ; and presumably it would be an easier install, i.e. no worries about bending it, crimping, etc. Definitely easier to handle than delicate aluminum. And cheaper too, probably?
Post by danrhodes on Aug 16, 2017 8:12:44 GMT -8
I do like that danrhodes ; and presumably it would be an easier install, i.e. no worries about bending it, crimping, etc. Definitely easier to handle than delicate aluminum. And cheaper too, probably? I think it might be a wash with aluminum as the only source I could find is the expensive Vintage Trailer Supply, but it's definitely a 5 minute install.
Post by mel on Aug 16, 2017 9:13:21 GMT -8
thanks danrhodes , its looks nice I like that one. I like that it comes with a lot of color choices too
theresa
Post by theresa on Aug 17, 2017 16:53:53 GMT -8
Mel, why do you say you'd use something different for the corners? Do you not like the cove moulding you used? Or was it hard to use? SaveSave
Post by mel on Aug 17, 2017 18:45:04 GMT -8
I like it and it looks nice. I only only use something different because the way I installed the countertop would be different next time so it wouldn't work then. My Formica was just like the original attached to thin Masonite then sat on top of a thicket piece of wood, but next time I would cement the Formica right to the thicker wood, seems like it would be stronger that way.
