mcal67
1967 Shasta Airflyte
Post by mcal67 on Jul 24, 2017 19:42:12 GMT -8
Hi all, new member here with a 1967 Shasta Airflyte. Sloooowly working on repairing, remodeling and in a nutshell...getting her back to her beauty. Brought it home about 6 months ago, managed to do several repairs already but of course a ton of things left on my list before the maiden voyage.
Couple of things already done: Replaced broken front glass Replaced and wired in a chandelier in the dining area Sealed the roof with a TPO rubber sealant (I believe my wife found on here) Tore the floor out in the rear of the trailer, replaced damaged joists, replaced insulation, replaced flooring Replaced damaged/rotten bed frame Replaced water line and drain at the sink (replaced old pressure gauge) and tested
Next on the list: New junction box New receptacles with usb ports New wiring for the handle by the door Wire cup cleaning and under coating on the frame Replace tongue jack Replace teardrops and brake lights with LED
Should be enough for first thread I suppose.
Thanks for having me here, MCAL
mcal67
Post by mcal67 on Jul 24, 2017 19:48:24 GMT -8
I know you guys wanna see some pics so here's a few Some of the roof work. Of course I found bull on the vent cover so I removed that and installed the Eternabond RV tape. Here's a bad pic (sorry) after 2 coats of the rubber sealant
mcal67
Post by mcal67 on Jul 24, 2017 19:50:12 GMT -8
Bed frame before... After....
mcal67
Post by mcal67 on Jul 24, 2017 19:51:57 GMT -8
More pics to come as I venture into more repairs. Again, thanks for having me....location is Alabama..Cheers all
Post by vikx on Jul 24, 2017 23:18:28 GMT -8
Welcome mcal67,
Glad you are happy with your Shasta! We don't recommend sealants or tape on the roof, so you probably heard of TPO? elsewhere?
Regardless, we always recommend lifting the skins to repair rot and never applying sealants. Water seeks the lowest point, so much of trailer rot is coming from the top, trickles down the walls and rots the skirts/sills. Check your edge trim/awning rails for bad putty. Putty fails after about 15 years (or sooner) so that is a likely water ingress area.
We are here to help.
aslmx
Post by aslmx on Jul 26, 2017 15:25:42 GMT -8
More pics to come as I venture into more repairs. Again, thanks for having me....location is Alabama..Cheers all Where in Bama are you? We're doing a 67 also but it's a total rebuild. It's been a slow go with the hot weather.
mcal67
Post by mcal67 on Jul 26, 2017 17:48:04 GMT -8
Birmingham aslmx. Yes the heat...well mostly humidity and the rain...plus working a ton has crippled my time on the camper.
aslmx
Post by aslmx on Jul 26, 2017 18:24:14 GMT -8
Birmingham aslmx. Yes the heat...well mostly humidity and the rain...plus working a ton has crippled my time on the camper. Yea the rain doesn't help either. I'm in Cullman so I pretty much get the same rain as you do.
