barefootonthefarm
'64 Yellowstone
Post by barefootonthefarm on Jul 4, 2017 11:25:41 GMT -8
Im looking at the 2410 for my install. Im concerned with the measurements. It says 32-7/8"H x 21-3/16"W x 24"D. I can't tell if that is overall size including the front that extends out a bit or if that's what the opening needs to be. My opening is 20.75 wide. That's the measurement I'm concerned with.
If someone has this fridge could you help me out and take some measurements? thanks so much!
Post by vikx on Jul 4, 2017 20:34:04 GMT -8
Do a search on Dometic 2410 rough opening. You will have to widen the opening, not too difficult with a multi tool. Also, be sure there is enough clearance at the back (the manual will tell you, usually an inch)
One of my trailers had an after market fridge install and the wood was scorched at the chimney opening, so be sure to follow the instructions exactly and measure twice.
