aslmx
Post by aslmx on Jun 11, 2017 5:37:55 GMT -8
I'm going to use a mini fridge so I really don't need this huge vent on the outter siding. Should I try to seal the hole and leave the original louvred cover on the outside?
Post by nccamper on Jun 11, 2017 8:24:42 GMT -8
I just installed a very quiet mini fridge that puts out almost no heat so I left the new skin uncut and eliminated the previous owner's vent. I vented the cabinet inside so there can be air movement if needed...but I don't think it is needed.
aslmx
Post by aslmx on Jun 11, 2017 10:19:40 GMT -8
I just installed a very quiet mini fridge that puts out almost no heat so I left the new skin uncut and eliminated the previous owner's vent. I vented the cabinet inside so there can be air movement if needed...but I don't think it is needed. That's my dilemma, I'm not going to reskin so I'm not sure what to do with the hole. Maybe a piece of metal behind the vent with butyl tape and screws?
Post by nccamper on Jun 11, 2017 13:12:00 GMT -8
That's my dilemma, I'm not going to reskin so I'm not sure what to do with the hole. Maybe a piece of metal behind the vent with butyl tape and screws? "A piece of metal behind the vent with butyl tape and screws?" It should be fine with the vent over it. I'd seal it then spray the area with a hose and check for leaks. The vent itself is added protection.
chuckz
Post by chuckz on Nov 9, 2017 9:15:01 GMT -8
Do you still have the vent and do you think it will work on a 1972 1400?
aslmx
Post by aslmx on Nov 14, 2017 19:08:14 GMT -8
Do you still have the vent and do you think it will work on a 1972 1400? I still have it. I'm not replacing the siding so I have to have it. I'm going to use the vented louver part on the outside but I'm going to put metal on the inside of it.
chuckz
Post by chuckz on Nov 15, 2017 15:20:25 GMT -8
aslmx, Is there a chance you could post a picture of what you have? It would really be helpful. You may have exactly what I need.
Post by Ten on Nov 15, 2017 17:33:06 GMT -8
The fridge vent on a '72 1400 should look like the one on this 16SC, top door on the front end:
aslmx
Post by aslmx on Nov 17, 2017 20:05:23 GMT -8
aslmx, Is there a chance you could post a picture of what you have? It would really be helpful. You may have exactly what I need. [ This is what I have. I will still be using it though.
chuckz
Post by chuckz on Jan 7, 2018 18:36:01 GMT -8
I'm sorry that I'm just now finally replying to your earlier post. No, what I'm talking about is the cover that is mounted on the roof.
Post by Ten on Jan 7, 2018 20:14:28 GMT -8
chuckz
Post by chuckz on Jan 9, 2018 12:55:09 GMT -8
Ten, That is exactly it. Thanks so much.
Post by mobiltec on Jan 10, 2018 16:40:55 GMT -8
Just cover it with a piece of metal, a lot of screws and some putty tape or OSI gutter seal.
Post by vikx on Jan 10, 2018 21:19:11 GMT -8
I covered the one in BB's roof just as Mobil described. Raised and re-framed under the roof hole so the screws would have plenty of bite and cut a piece of metal to fit. NOTE: I tried metal of the same pattern and it didn't fit the slight lift from the shims (1/2") Metal with a pattern 90* off fit MUCH better. Anytime a roof is patched or a protrusion is added, shims will allow water to run away from the patch. I used pure butyl putty and screwed the patch down. I then painted two coats of Proflex paint on sealant (not the caulk) over the top, screw heads and edges. After paint, any tiny gaps are easily visible. Dab a small amount of OSI gutter seal over them and smooth with a paint thinner dipped finger. You want it as smooth as possible. Touch up the paint. Reseal if you see any gaps. 63bbtrailer.shutterfly.com/pictures/207#204 Scroll back and forth to see more photos.
