bev
Post by bev on Jun 1, 2017 16:34:49 GMT -8
I think my build of my 1970 starflyte is on the same timeline as Lady Gwen. I purchased a 26 gal fresh water tank with no prebored holes. I don't care to invest in a spinweld tool, as cool as it is, since it's so expensive. I'm thinking of using this Uniseal product: www.tank-depot.com/product.aspx?id=1611. Has anyone used this type of fitting before? 2. Recommendation for another type of fitting that has proven successful? 3. Also, i plan a using these fittings: drain fitting, 1.5" gravity water fill, city water fill with check valve, supply to water pump and vent. What do yall think of this? 4. What vent valve do ya'll like to use? both of my fill valves doe not have a built in vent. Thanks in advance.
Post by vikx on Jun 1, 2017 21:16:02 GMT -8
I would pay the local RV shop to spin weld to match your configuration.
The city water isn't connected to the tank system, so eliminate that from the equation. The fill and all sound OK.
bev
Post by bev on Jun 2, 2017 2:49:28 GMT -8
That's right, I wasn't thinking right, city water comes in after the pump. Thanks
