Post by mobiltec on Sept 1, 2017 5:23:18 GMT -8
Yep and what I do is 3 coats of amber and then two coats of clear. With sanding between coats, at least I would. You need to have at least two coats on before you begin sanding. And then you use very light weight sand paper. 220 grit tops.
Post by mrmarty51 on Sept 1, 2017 9:24:31 GMT -8
With sanding between coats, at least I would. You need to have at least two coats on before you begin sanding. And then you use very light weight sand paper. 220 grit tops. YUP, the smoother the under coats the smoother the finished product will be. It seems that 400 grit is My go to stuff.
Post by mrmarty51 on Nov 14, 2017 22:14:41 GMT -8
I run carriage bolts through the bottom wall plate, through the floor and through the trailer frames outriggers. Used nylok nuts after I got the bolts heads sunk in and anchored. also plenty of screws between the bolts into the floor framing. I do not think it`ll be going anywhere. LOL
Post by mrmarty51 on Nov 16, 2017 4:55:06 GMT -8
I run carriage bolts through the bottom wall plate, through the floor and through the trailer frames outriggers. Used nylok nuts after I got the bolts heads sunk in and anchored. also plenty of screws between the bolts into the floor framing. I do not think it`ll be going anywhere. LOL You must be careful though when installing the nylock nuts, that the bolt does not turn. I used a pair of vice grips and gently squeezed the bolt threads above the nylock then after there was enough room, moved the vice grips below the nut.
Post by vikx on Nov 16, 2017 20:45:42 GMT -8
I use lock washers and regular nuts rather than fight with the nylocks. A person can always add a little thread lock to the regular nuts.
skipnwendy
Post by skipnwendy on Nov 18, 2017 6:03:45 GMT -8
Love seeing the way folks do these! Looks Great so far!
Post by ladywendolyn on Feb 24, 2018 14:45:20 GMT -8
I have one question. Is it a Shasta thing to use 1/4 inch plywood on the curve? I was under the impression that it always 1/8 used on most trailers. Just curious.
Post by vikx on Feb 24, 2018 20:45:02 GMT -8
My Shastas have 1/8 on the curves and ceilings, but they're older hams, 1957. The newer Shastas had the faux blond paneling, it was thicker if I remember right.
Post by vikx on Feb 25, 2018 21:27:45 GMT -8
sherrifriend, once you get the panel curved, you might consider filling the kerfs with a wood filler product. Some are epoxy, that should work. Then you can sand smooth and you'll have a very sturdy panel.
Post by mobiltec on Feb 26, 2018 8:16:56 GMT -8
I'm very interested in how this kerfing method works for you sherri. Especially if you fill the voids like Vikx is suggesting. This is something I have only done a very long time ago on the edge board pieces for the Deville.
Post by mrmarty51 on Apr 12, 2018 8:00:01 GMT -8
Great progress Sherri, beautiful workmanship too. You will have it all finished before long now.
Poquito
Post by Poquito on Apr 12, 2018 15:42:11 GMT -8
Great work Sherrifriend! You are tenacious in your ability to not let adversity stop you from completing this project. I am in awe, my friend. Can't wait to see and read how you wrap this thing up before the neighbors start twittering again! BTW, didn't see if you found a source for the metal roofing. Did you?
Poquito
Post by vikx on Apr 12, 2018 20:08:29 GMT -8
Wow, it looks great! Find out the quality and scratch resistance of the Lexan. I think glass would be better.
HOTRODPRIMER
1957 Shasta
Post by HOTRODPRIMER on May 23, 2018 7:08:56 GMT -8
Congratulations,your hard work and diligence shows. Danny
Post by mel on May 23, 2018 16:14:35 GMT -8
Looks great!
