roadtripper
Post by roadtripper on Feb 20, 2017 13:54:27 GMT -8
The pic is the corner of one of the sliding windows in my door. (See: can I get this door apart). To get the glazing out should I pry the corners open or drill out the dimples in the bottom corners. The top rail is a bit more complicated as it has the catches for the slide involved. I looks like the 1/8" rubber channel on vts will fit. Thanks. IMG_3929
