Post by mel on Oct 1, 2016 18:54:24 GMT -8
My plywood needs to be completely smooth for my sheet vinyl install. I have seen some people some kind of filler then sand it, and some use a thin layer of smooth wood. What are the pros and cons of each? Also has anyone used floor self leveler? My step dad suggested it.
Post by danrhodes on Oct 1, 2016 19:26:05 GMT -8
My plywood needs to be completely smooth for my sheet vinyl install. I have seen some people some kind of filler then sand it, and some use a thin layer of smooth wood. What are the pros and cons of each? Also has anyone used floor self leveler? My step dad suggested it. Self leveler usually concrete...bad choice. I'd consider either wood putty or bondo. You can add a layer of luan, but the height increase might be a problem
Post by vikx on Oct 1, 2016 22:12:23 GMT -8
I use Luan over the old subfloor. It smooths everything out and no "burbles" in the vinyl... Most of the time, if you fit the Luan, fillers aren't needed. For instance, seams can be at or under the dinette or cabinet.
Post by nccamper on Oct 3, 2016 5:13:08 GMT -8
I've used Luan (Sureply) with very good results. The debate is always glue or no glue. The manufacturer says just use staples on residential use. I glue a little in key spots since we are using it in a moving, shaking, vibrating home. With that said, I'd rather have a smooth, solid 3/4" plywood surface but life is full of compromises.
Post by mel on Mar 4, 2017 6:00:35 GMT -8
I have been ordering samples of sheet vinyl and the price seems a bit high for my budget. So I guess I am now considering the VCT tile that most of you use in your trailers. It would be nice if a few people could give me a ball park on how much it cost you to vct tile your trailer???
Post by nccamper on Mar 4, 2017 15:40:07 GMT -8
It would be nice if a few people could give me a ball park on how much it cost you to vct tile your trailer??? I spend about $45 a box for the tile at Home Depot. I always order two boxes but in the Compact I think I only used one. Luan around $20 a sheet- two sheets Glue and cleaner escape me at the moment but try to use Armstrong Glue. I like it much better than the cheap store brand which seemed too gummy. I thought I'd take up the flooring and save on Luan for the Forester but it seems like an Asbestos dust storm leading to a less than perfect surface.
Post by mel on Mar 4, 2017 19:50:49 GMT -8
Post by ladywendolyn on Mar 4, 2017 20:13:43 GMT -8
I use Luan over the old subfloor. It smooths everything out and no "burbles" in the vinyl... Most of the time, if you fit the Luan, fillers aren't needed. For instance, seams can be at or under the dinette or cabinet. 1/8 luan or 1/4 inch? SaveSave
Post by vikx on Mar 4, 2017 21:40:20 GMT -8
3/16", most stores carry it, specifically for underlayment.
Post by ladywendolyn on Mar 4, 2017 22:07:15 GMT -8
3/16", most stores carry it, specifically for underlayment. But it's wood? Not particle board? SaveSave
Post by vikx on Mar 4, 2017 22:10:16 GMT -8
It's luan plywood. Not sure all stores call it that. It might have a mdf core but it's great for a smooth underlayment. The stuff I get here is mahogany on the good side, kind of pink. Of course, we all know different areas have way different products. I would ask a flooring person in your neck to see what they like best.
Post by nccamper on Mar 5, 2017 6:16:04 GMT -8
It's luan plywood. Not sure all stores call it that. It might have a mdf core but it's great for a smooth underlayment. The stuff I get here is mahogany on the good side, kind of pink. Of course, we all know different areas have way different products. I would ask a flooring person in your neck to see what they like best. Do you glue the entire piece of luan or just staple...or a combination of the two? I've been in the combo group but I'm wondering if 100% glued might be better.
Post by ladywendolyn on Mar 5, 2017 7:20:14 GMT -8
Thanks fir the info @vikx. I am hoping that i won't need a subfloor, but we won't know until are scrape off the old layers.
Post by vikx on Mar 5, 2017 11:30:19 GMT -8
I've used glue but didn't think it really "stuck" that well. I use staples to secure it and sometimes a screw where it won't show.
Post by nccamper on Mar 5, 2017 15:41:07 GMT -8
