Post by redfancamper on Jun 26, 2016 17:14:21 GMT -8
Hello all, I am new to this forum, but not new to forums. I've read thru most of the solar power threads and a lot of the information was great. We just purchased our first camper ever (I'm coming from a 1970 VW Westy Campmobile) and I want to do some boondocking. So my opinion question is would you rather have a solar panel installed on top of the camper to charge batteries, or pick up something like the Goal Zero 31901 Yeti 1250 to power the things I need in my camper? I've done research on the Goal Zero 31901 Yeti 1250 and there seem to be mixed reviews, so I'm kind of leaning towards installing solar panels like this guy did: But I would like to get everyone's thoughts. I do understand there will be a considerable cost for either one. I'm not too sure about the Harbor Freight solar system as I've never been there before. So I will definitely check out their system too.
Thanks in advance for your help/thoughts/comments.
Post by vikx on Jun 27, 2016 22:34:18 GMT -8
Welcome!
I would NOT install a solar panel on the roof of any camper trailer. They vibrate going down the road and the bolts always leak.
So, a movable solar stand or goal portable should be considered.... Not sure either will supply your needs.
More research, learn....
Post by nccamper on Jun 28, 2016 4:38:05 GMT -8
Welcome!
I have a neighbor who has an expensive portable solar setup for his small camper. It doesn't do him much good "unless it is in direct sun" meaning, usually, the worst campsite. He says it's worth doing just to reduce his environmental footprint. I like my big fully powered foot.
Post by redfancamper on Jun 28, 2016 6:31:18 GMT -8
Yes, thanks for the replies fellow campers. I spoke with a close friend of mine who is both and avid RV'er and he works for a Solar Company that sells solar for homes. He said the tech is just not there yet and I would be better suited buying myself a little Honda Whisper quiet generator to operate off. So I think I'm going that route.
I am very new to the RV world, so I've been doing quite a bit of research on how to keep these things going and having fun.
Post by nccamper on Jun 28, 2016 6:38:53 GMT -8
... I would be better suited buying myself a little Honda Whisper quiet generator to operate off. So I think I'm going that route. I've only heard good things about Honda generators.
Post by kto17 on Jun 28, 2016 7:02:37 GMT -8
I have a Honda EU2000i. I LOVE it.
It runs like a top. They sip fuel so they are prone to carb gumming. They are best stored with no fuel, even drain the fuel bowl, and running the last tank with stabil before running out. I add the more expensive (auto parts store product, not gas station) Chevron techron fuel additive to the first tank and let it run for and hour or two for the first fire up of the season. If it won't idle right or surges that additive usually will clean it out and will it will run right after that.
On the Econ mode, low rpm idle until more power is required, is so quiet you can stand beside it and talk on the phone. I think if you built a 4 sided box of 2" foam to direct the sound up and deaden it, you could possibly run one after ours if the site beside you wasn't too close.
I would say the biggest negative is at 47 lbs and $800-$900 used they tend to grow legs and runnoft if you don't chain them down. Also, don't leave it out when you are leaving your camper for an extended period of time.
mtpalms
Post by mtpalms on Jul 5, 2016 19:36:12 GMT -8
I read through the other solar related threads, and for my needs they are overkill. At the moment, my trailer has two things that run on 12V: the water pump and the dome light. I would also like to charge small electronics like a cell phone and tablet though. I also do not have much room to store things. I looked at the Goal Zero products and liked what I saw, but then I found a less expensive set up, the King Solar 60 watt foldable solar system. www.amazon.com/gp/product/B00QF2NX0Q/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A3QUWC2QIV3WZFA small set up like this only requires a small controller, such as this 10 amp PWM controller, to charge a 12 volt battery. www.amazon.com/gp/product/B00F0A2ZMG/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3VAEX6T4LXLDZThanks to this forum, I found out I can also pick up a decent dry battery at Harbor Freight! I am planning on installing the battery under the sink next to where the water pump is - -that is, once the cabinets are rebuilt. I still have plenty of time to do more home work.
Post by cowcharge on Jul 25, 2016 0:08:33 GMT -8
Welcome! I would NOT install a solar panel on the roof of any camper trailer. They vibrate going down the road and the bolts always leak. So, a movable solar stand or goal portable should be considered.... Not sure either will supply your needs. More research, learn.... You don't have to put bolts through the roof... My plan is to have the bolts go through the j-rail while the mounting rails just rest on the roof. But people have been successfully bolting things into roofs for eons (or under water through boat hulls, for that matter). If you can seal a roof vent you can seal a few bolts. It's all a matter of how well it's done... Having said that, if you're going to depend on solar and have it on your roof, you kinda have to park in the sun all the time. Even here in Maine, with probably the heaviest-insulated Shasta ever built, it gets hot in there. As for generators, even the quietest one can be heard a long distance away. There's no way around it.
Post by vikx on Jul 25, 2016 21:15:08 GMT -8
The panels act like sails and put a lot more wear and tear on the roof bolts. You're right they can be sealed, but MUST be inspected and maintained often. I have been surprised at how quickly things go awry with roof mounted solar panels.
Much handier to be able to place them in full sun...
Post by SusieQ on Jul 25, 2016 21:29:19 GMT -8
I have (expensive) mobile suitcase panels and I love them. My are 80w and good enough for replenishing the power used by the fan and led lights, and a little radio and TV. Just don't expect them to fully charge a dead batter, it won't work!
Post by cowcharge on Jul 26, 2016 10:46:25 GMT -8
I think the "sail" effect must be more pronounced on Compact-type campers due to their rather flimsy construction. How small are the rafters in those things, 3/4"? Mine are about 3" in the center, tapered down to 1.5" at the ends. Basically tapered 2 x 4s.
