Post by danrhodes on Jun 23, 2016 7:20:09 GMT -8
Mines in pretty good shape, originally covered with vinyl. I've been airing them out to try and remove the smell of the chinese herb cache that was hidden in the cabinets. I'll also try the vodka santizing trick before recovering.
Post by nccamper on Jun 23, 2016 10:20:26 GMT -8
I reused the foam on our Compact and it worked out fine. Although the original foam was a little thin. I like 6" foam better.
Is your old foam comfortable enough to sit on for long periods of time? That's the real question.
theresa
Post by theresa on Jun 23, 2016 14:23:32 GMT -8
I'm looking for someone's used foam from a gaucho bed to remake mine that are missing. I've heard of people cleaning/disinfecting their foam in a vodka solution and reusing. I'd be hesitant to use thicker foam at least on a dinette as that will raise the height and you'd have the potential of hitting your legs on the table?
lovnvintage
Post by lovnvintage on Jun 23, 2016 15:14:48 GMT -8
Not sure he is talking about the spring cushions. If so mine did not originally have any foam. Only a mat of strange looking stuff but in good shape, batting, muslin and batting. I threw out the batting and used a 2" pc. of foam and new batting. Much softer but not too tall for the dinette.
Post by danrhodes on Jun 23, 2016 15:42:17 GMT -8
Not sure he is talking about the spring cushions. If so mine did not originally have any foam. Only a mat of strange looking stuff but in good shape, batting, muslin and batting. I threw out the batting and used a 2" pc. of foam and new batting. Much softer but not too tall for the dinette. Yeah, mine's all foam...maybe 4 inches. It's fine to sit on for a while...about as fine as sitting at a tiny flimsy table is going to be for 6'2" me. I assume that the quality is probably as good or better than what I would want to pay for nowadays. I guess I could make it a little thicker with some carpet padding sandwiched, but I think it's OK as is if I can get the smell totally out.
Post by nccamper on Jun 23, 2016 18:23:54 GMT -8
I'd be hesitant to use thicker foam at least on a dinette as that will raise the height and you'd have the potential of hitting your legs on the table? I remade the table leg to raise it 1 1/2" which worked perfectly. I thought 4 inch foam was a little rough to sit on for more than 20 or 30 minutes at a time. Pillows also help eliminate the 90 degree angle effect.
Post by danrhodes on Jun 23, 2016 18:28:57 GMT -8
I'd be hesitant to use thicker foam at least on a dinette as that will raise the height and you'd have the potential of hitting your legs on the table? I remade the table leg to raise it 1 1/2" which worked perfectly. I thought 4 inch foam was a little rough to sit on for more than 20 or 30 minutes at a time. Pillows also help eliminate the 90 degree angle effect. I have a 3 and 5 year old... We don't do anything for more than 20 minutes at a time.
Post by SusieQ on Jun 24, 2016 4:18:21 GMT -8
If your foam is in decent shape and you can't squeeze it all the way together with your fingers, then it's perfectly fine to use. You can always beef it up with another thin layer. I used 4" foam with a 2" memory foam topper. It makes for a very comfy sleeper. Also, wrap your foam in batting.
I don't have an issue with my knees hitting the table, I'm just thankful my feet touch the floor, but it did raise the back cushion to the very bottom of my window. Any thicker and my back cushion would have been above my window. Make sure you get your cushion cover to fit very snugly. The foam topper squishes in the tight cover and makes a very smooth looking surface but still conforms when you sit or lay on it.
I've read the vodka wash idea for sanitizing and have given that some thought. I'm sure that drenching foam in alcohol is such a good idea; would it cause the foam to deteriorate faster? Not sure. You can wash it, just make sure you wring it out well and let it dry thoroughly. But unless it is really disgusting, in which case just through it away, it is going to be "sealed" in the batting and cover.
Post by nccamper on Jun 24, 2016 4:30:34 GMT -8
When I bought the Compact at the Utah boarder I drove out on my own, picked up the camper, went to a campground 10 miles away and rented a steam cleaner from the supermarket. I then cleaned the cushions three times with deodorizer and let them dry in the desert sun while I scrubbed the camper down before my wife flew out to see it.
She then arrived and cleaned everything again.
Post by SusieQ on Jun 24, 2016 5:17:51 GMT -8
She then arrived and cleaned everything again. Priceless!
harryinwis
1968(?) Woodsman
Post by harryinwis on Oct 9, 2016 5:46:33 GMT -8
I'm looking for someone's used foam from a gaucho bed to remake mine that are missing. I've heard of people cleaning/disinfecting their foam in a vodka solution and reusing. I'd be hesitant to use thicker foam at least on a dinette as that will raise the height and you'd have the potential of hitting your legs on the table? This wasn't an issue for me. I bought my camper with no dinette. I had to take the thickness of the foam when I built the seats.
