Post by vikx on Aug 12, 2017 21:19:41 GMT -8
I use screws on the underskins.
Post by Teachndad on Aug 13, 2017 5:19:31 GMT -8
Make sure you select the proper length of staples then experiment with the amount of air pressure you need. Make sure you buy a regulator so that you can maintain constant air pressure, if not you will hate your stapler and say it is junk. Many people try to use a flow valve to regulate air but they will not work with a stapler or nail gun. It requires constant air presssure or you will be driving staples completely through the top layer of material, aluminum or paneling. Hi Friends, Can you post a sample of a regulator, Bill? BTW, great thread. Thanks, Rod
Post by kirkadie on Aug 13, 2017 6:34:54 GMT -8
stanley
still eager, not yet jaded!
Post by stanley on Aug 13, 2017 7:29:44 GMT -8
Any particular kind/length?
I was also thinking of using fence post paint along the underside skin to seal all those old holes from the removed staples. Good idea?
Post by bigbill on Aug 13, 2017 8:34:22 GMT -8
Make sure you select the proper length of staples then experiment with the amount of air pressure you need. Make sure you buy a regulator so that you can maintain constant air pressure, if not you will hate your stapler and say it is junk. Many people try to use a flow valve to regulate air but they will not work with a stapler or nail gun. It requires constant air presssure or you will be driving staples completely through the top layer of material, aluminum or paneling. Hi Friends, Can you post a sample of a regulator, Bill? BTW, great thread. Thanks, Rod They come in many different styles over a large price range starting with one such as kirkadie showed above. Just make sure the one you buy says it supplies a constant air pressure.
Post by danrhodes on Aug 13, 2017 10:19:37 GMT -8
Post by Teachndad on Aug 13, 2017 21:57:50 GMT -8
Hey Dan, Bill, and Kirk,
Thanks! I will put it in my files. Not anywhere near using a compressor, but the info will be saved.
Cheers!
