chametzoo
1960 Mobile Scout
Post by chametzoo on Apr 17, 2016 16:30:50 GMT -8
Hi All... I'm looking for informed opinions. The picture attached here is of my electrical bay in my 1960 Mobile Scout. During restoration it was wired and laid out by a professional electrician. It's mostly a 12V system (a few 110V outlets for shore hookups.) To the left are two 6V golf cart batteries in series. On the right is a PD4045 Progressive Dynamics Charger/Controller. It maintains the battery and reduces shore power to 12V. At the top of the picture is an exhaust fan that draws air out (about 52 CFM according to specs) through a vent panel in the exterior wall. Over the top opening of the electrical bay goes the seat cushion for the dinette bench. On the front of the bay at the bottom (out of site) is a toe kick diffuser/vent panel that allows trailer interior air to be drawn across the bay by the fan. As per a lengthy PM conversation with our fellow member "Cowcharge", I am planning on adding a TriStar solar charger for battery charging while boon docking. Our conversation brought up some concerns about the proximity of the batteries during heavy discharge/recharge cycles while boon docking and off grid camping, to the other electrical devices within the bay (chargers, fan, etc.). Active batteries produce Hydrogen gas, which is lighter than air and tends to hover above in enclosed spaces. If left with no escape, sparks from electrical systems or static discharges can ignite such gases. I have a plan on the drawing board to box the batteries and provide a high vent outlet connected by flexible dryer ducting to the fan and to fresh air. The box will also have a low vent to let fresh air in. This plan will involve some rearranging and modifications of the bay to make it work, so I'm not anxious to do it if I don't have to. The area inside the bay within the dinette bench has a lot of open space and moving air, so at first I was not concerned about the layout as the electrician provided it. Please chime and with your opinion as to the safety of the current layout with batteries un-boxed and electrical bay actively ventilated with the fan which runs all the time. Thanks!
Post by vikx on Apr 17, 2016 21:36:43 GMT -8
That is one of the best looking electrical layouts I've seen in a trailer! Wow and kudos to the electrician.
I am a bit concerned about the batteries being exposed and not in their own contained compartment. The venting should work but I'm uncomfortable with the close electrical components; that could be a hazard. Is the fan/venting enough? I would ask your electrician and disciss automotive/golf cart batteries and see what he says.
Most of the time, people get away with batteries in the coach with varying degrees of compartmentalizing. Optimas are said to be safer (less off gassing) but the reps won't guarantee that. (wonder why?)
Thoughts: 1. Build a "wall" between the batteries and components and add a 2nd fan? 2. The fans could be a problem when boondocking. Anything with a motor will drain the power supply. If you are in full sun, not a big deal. Shade, not so much. 3. Passive ventilation is often enough in a battery compartment. The fan may be the ticket.
Please update us. This is an important discussion.
chametzoo
1960 Mobile Scout
Post by chametzoo on Apr 18, 2016 8:17:24 GMT -8
That is one of the best looking electrical layouts I've seen in a trailer! Wow and kudos to the electrician. I am a bit concerned about the batteries being exposed and not in their own contained compartment. The venting should work but I'm uncomfortable with the close electrical components; that could be a hazard. Is the fan/venting enough? I would ask your electrician and disciss automotive/golf cart batteries and see what he says. Most of the time, people get away with batteries in the coach with varying degrees of compartmentalizing. Optimas are said to be safer (less off gassing) but the reps won't guarantee that. (wonder why?) Thoughts: 1. Build a "wall" between the batteries and components and add a 2nd fan? 2. The fans could be a problem when boondocking. Anything with a motor will drain the power supply. If you are in full sun, not a big deal. Shade, not so much. 3. Passive ventilation is often enough in a battery compartment. The fan may be the ticket. Please update us. This is an important discussion. Vikx… thanks for your sage comments. I don't think the electrician is the one to consult on this issue. The evidence of what he thought was correct and safe can plainly be seen in the existing electrical bay layout, even despite his excellent design and execution of the system itself. He opted for a fan instead of a box. I had considered building that "wall" you are talking about; seems pretty straight forward. I would use flexible dryer vent and exhaust to the existing fan opening (not interested in making more holes in the trailer exterior). But to the left of the batteries is a 110V and 12V outlet mounted on the front face of that dinette bench and I consider this to be the biggest risk to a possible spark discharge when plugging something in etc. You can see the yellow wire leading to the 110 in the lower left of the photo. It's all just inches from the battery bank! So the wall would really have to be 2 walls, one right and one left. I think a container for the batteries, along with the flexible vent to the fan, would be easier to build and install. So in general, I share your concerns. Though the likelihood of an event is extremely low in my opinion… a 'perfect storm' of circumstances might blow one of those 6 volts!… that's the definition of an "accident"! In the box scenario, I think the fan is a necessity even though it will suck up power when boon docking. Passive venting: for it to be reliable, there should really be a stack straight up out of the top of the battery box (w/ a fresh air source near the bottom). Obviously, with the batteries under the bench that's not going to happen. So I will vent from the top of the right side of the box and let the fan pull the hydrogen out and the fresh air in. My fan, according to specs, consumes 1/3 of an amp… but when off grid, that's 7 Amp Hours in a day. My 100W of solar panels would need over an hour of direct sun just to make that up. But the 1/3 amp is rated at 3 to 7V according to the fan's specs. Of course the fan is connected to a 12V system (which may shorten its lifespan). So would it stand to reason that the amperage would be lower operating at 12V (Watts=Volts X Amps) rather than the 3 to 7V? My knowledge of electrical physics is a little fuzzy .
Post by vikx on Apr 18, 2016 10:08:09 GMT -8
Is there any way to build a battery tray and put them on the tongue? This would give you more space inside and eliminate the need for enclosing/ventilating the batteries. Heavy duty wires from battery bank to the converter would take care of the distance.
I've only put my batteries on the tongue. Eliminating one LP tank is one way to do it, the other is to build a dropped battery rack behind the tanks. Re-positioning the tank plate may be necessary, but where's there's a will, there's a way... Aristocrats are an exception when it comes to battery placement. They have a side "cargo" for the battery from the factory. Most of the doors are not louvered; ventilation is accomplished thru the loose fitting door edges.
Note: One battery exploded in the Aristo Land Commander. We've never discovered why, theory is that the small charger failed and overcharged? What ever the reason, the battery is now on the tongue.
As far as the fan amperage, I'm as fuzzy as you are. LOL. There are reducers to adjust voltage to the fan, that would give it just what it called for.
chametzoo
1960 Mobile Scout
Post by chametzoo on Apr 18, 2016 12:08:34 GMT -8
Is there any way to build a battery tray and put them on the tongue? This would give you more space inside and eliminate the need for enclosing/ventilating the batteries. Heavy duty wires from battery bank to the converter would take care of the distance. Hmmm… that was an obvious one all along, but I haven't let myself go there . The front is so much cleaner without that… But let me actually look at the dimensions etc. I would only do it, if I could move the tanks forward a minimal amount and slip the box in behind them. Dropping it as you suggest would also keep it fairly stealth. There is a nice box for twin 6V golf cart batteries from Century Plastics where the batteries fit in short end to short end: 22" long and only 8-1/2" wide. It's also of white plastic which might look better on this particular trailer rather than the typical black ones. Century Plastics: White Heavy Duty Battery Box - (part#: GCE-G)I'll take a look at the tongue and see how that could work a bit later and get back to you, Vikx. It would make the fan absolutely moot and redirecting some 4 gauge wire would pretty easy; just drill a hole in the floor. The more difficult tasks would be creating the support structure for the battery box and repositioning the tank platform. We'll see...
chametzoo
1960 Mobile Scout
Post by chametzoo on Apr 18, 2016 13:57:02 GMT -8
Vikx… nice try, but I don't think the batteries on tongue will work. The problem is that the canned ham shape of the front means that even when dropped, the battery tray would have to come so far forward to accommodate the 13" height of the box. At that point, the "V" of the tongue becomes way too narrow to accommodate the 22" width. If the box platform were not dropped and mounted on top of the tongue frame with a cantilever, it would have to come even further forward to accommodate the up slope of the front… that would leave no room for the LP tanks at all… and I'm keeping both tanks. Mounting the box in front of the tanks doesn't work either. My weight distributing brackets have to be where they are in order to work properly, so the tanks can only move back toward the trailer an inch or so. That does not leave room for any shape or kind of box up front between tanks and tongue jack column. So if I want 2 batteries and 2 tanks… it's no dice. But thanks for the idea, it looked promising just looking at the picture.
Post by vikx on Apr 18, 2016 20:24:10 GMT -8
Well drat. There really isn't another place to put the two big batteries. Sounded good, tho...
chametzoo
1960 Mobile Scout
Post by chametzoo on Apr 18, 2016 20:57:29 GMT -8
Well drat. There really isn't another place to put the two big batteries. Sounded good, tho… Yeah… drat! So, I'll go to my boxed battery bank plan with the container I've obtained. I think it'll work very well, but I'll still have the energy demand of the small fan when boon docking . Maybe I can find a lower current 12V fan to replace. I'll post pictures when I'm done in a couple of weeks…..
RinTin
Post by RinTin on Apr 19, 2016 5:50:39 GMT -8
You may want to consider ditching the charger/converter and switch to a modern controllable charger like one of these: <iframe width="420" height="315" src="https://www.youtube.com/embed/5veL6OsKzjI" frameborder="0" allowfullscreen></iframe> Expensive, yes, but they will also greatly increase the life of your batteries. These charge at a slower rate, which true deep cycle batteries prefer, thus minimizing the gassing. The only advantage I can see with the charger/converters is you can have 12V if your batteries are dead. However, in my opinion this is a false security as you should not be discharging batteries more than 50% in the first place. Besides, the charger/converter is useless while boondocking. A couple more links with more info: www.pbase.com/mainecruising/installing_a_marine_battery_chargerwww.sterling-power-usa.com/marinebatterychargerhome.aspxOne more thing, having the batteries and charger in the same small enclosure is never a good idea as the gasses are not only flammable but also very corrosive to the charger's electronics. Will the batteries fit in the tall closet in front of the wheel well? Also, there are low amperage solar powered 12v fans with battery power back up.
Post by cowcharge on Apr 19, 2016 7:14:07 GMT -8
It looks like you have the space to rotate your batteries 90 degrees and box them in at the rear of the compartment, which would give you the space to isolate them from the outlets in the front, and probably also to mount your Tristar in the same space.
Since batteries gas when charging, I still think that wiring the fan to only be powered when the converter or solar panels are operating would cut down on the power usage.
I don't know any way to reduce the voltage to match the fan that would not just waste the extra power instead of saving it, but I'm no electrical engineer either. In a quick search, a "switcher" was proposed as an efficient solution. I'm not sure it would cost less in installation time and price to be easier than just buying a 12v computer fan, though.
The converter already charges more slowly than the battery mfgr recommends, I don't think you need to worry about "excessive" gassing when on a hookup.
chametzoo
1960 Mobile Scout
Post by chametzoo on Apr 19, 2016 9:12:25 GMT -8
It looks like you have the space to rotate your batteries 90 degrees and box them in at the rear of the compartment, which would give you the space to isolate them from the outlets in the front, and probably also to mount your Tristar in the same space. Since batteries gas when charging, I still think that wiring the fan to only be powered when the converter or solar panels are operating would cut down on the power usage. I don't know any way to reduce the voltage to match the fan that would not just waste the extra power instead of saving it, but I'm no electrical engineer either. In a quick search, a "switcher" was proposed as an efficient solution. I'm not sure it would cost less in installation time and price to be easier than just buying a 12v computer fan, though. The converter already charges more slowly than the battery mfgr recommends, I don't think you need to worry about "excessive" gassing when on a hookup. I'm going to rotate each one 90 degrees so that they are long edge to long edge and box them on the left more or less where they are now. It will be easier for me to get both the batteries and the box in/out that way. Right now, the batteries are very difficult to get in and out. I can also slide the whole thing a few inches to the left (though there is not as much room there as the photo seems to show… to the left is mostly the curve of the front of the trailer and not floor). I will also run 4 gauge wire out of the box for + & - remote terminal blocks and eliminate the problem of gassing corrosion on the battery lugs which now have lots of connections piled up on them. As described above, the box will cover the batteries but will have generous perimeter venting at the bottom to draw fresh air in and up… the fan will do the rest and will be ported on the right upper side of the box and go straight to the exhaust fan. This will keep a constant flow from bottom, to top then outside. The dinette bench front will also have a low "toe kick" vent to take advantage of the negative air pressure in the electric compartment and provide ready fresh air. The Tristar solar controller can now be safely mounted to the right of the fan. The run to the solar panel connection outside will be very short… maybe 2 feet… plus about 10 feet of tether after that. Right now the fan does have an on/off switch that I can make convenient to reach. So I can at least do that manually for now. I'm not sure how I can make it automatically switch with the controller??? But I'm sure someone knows how to do that . As you suggest, another $10 12V fan with lower amperage may be in order. When parked at home, the trailer is almost always hooked up to the house. It maintains the batteries at only about 13.3V. If there is no load, it occasionally goes into "boost" mode and runs it up to 14.4, but only briefly. The 3 modes on the PD4045 are 14.4, 13.7 and 13.3. They're set and I have no manual control over them. But with the Tristar and 14.8V solar charging, the batteries will most definitely need to be isolated and vented. So that's what's going to happen.
Post by cowcharge on Apr 19, 2016 9:50:53 GMT -8
Ah, I didn't look closely enough, I thought all that wood in the box was flat floor. But turning the batteries ought to get you some useful space at the front.
I wouldn't worry that much about making the batteries easy to remove, you really shouldn't need to take them out very often. And I think it might remain easier if you just build a wall and a top, rather then adding a "real" battery box. You could just line it with PVC sheet like they use under shower stalls (sold in the Home Depot plumbing dept., PVC is very acid-resistant) if you're worried about spills. They also make nylon lifting straps that you can leave on the batteries to make things easier.
The Tristar is about 10.5" x 5" x 2", make sure wherever you put it, that you can still get to whatever is underneath.
chametzoo
1960 Mobile Scout
Post by chametzoo on Apr 19, 2016 10:33:38 GMT -8
Ah, I didn't look closely enough, I thought all that wood in the box was flat floor. But turning the batteries ought to get you some useful space at the front. I wouldn't worry that much about making the batteries easy to remove, you really shouldn't need to take them out very often. And I think it might remain easier if you just build a wall and a top, rather then adding a "real" battery box. You could just line it with PVC sheet like they use under shower stalls (sold in the Home Depot plumbing dept., PVC is very acid-resistant) if you're worried about spills. They also make nylon lifting straps that you can leave on the batteries to make things easier. The Tristar is about 10.5" x 5" x 2", make sure wherever you put it, that you can still get to whatever is underneath. The other thing you can't see in the photo is the back side of a 110V and 12V convenience outlets to the left of the batteries. They are accessed from the front side of that dinette bench. They're just an inch or two from the batteries and I consider them to be the highest spark risk. So I would have to build a wall on the right, one on the left and another on top and make them tight and/or ventilated where need be. It will actually be easier for me to modify a box and drop it in. That is, unless you think those outlets are not a spark hazard in such close proximity, let's say during heavy charging. Certainly the 110 will not be hot unless connected to shore power, but the 12V (which doesn't have to be contained in a metal box like 110) will always be hot. Right now the batteries just sit on the floor. When I do it, they'll sit in a metal pan and the plastic battery box will go over the batteries. As you can see, the electrical system was designed precisely and correctly, but from an "RV" use standpoint, many things were not considered regarding battery safety, access and power consumption off grid. Hence… this thread .
Post by cowcharge on Apr 19, 2016 10:48:07 GMT -8
I'd separate the batteries from everything I could. Pretty much any time you plug something into a live outlet, there's a spark, even if it's just static.
chametzoo
1960 Mobile Scout
Post by chametzoo on Apr 19, 2016 10:57:14 GMT -8
I'd separate the batteries from everything I could. Pretty much any time you plug something into a live outlet, there's a spark, even if it's just static. Yup… that's what I thought. Thanks.
