jerfo
Post by jerfo on Oct 3, 2015 8:10:13 GMT -8
Heya everyone so i'm almost done with all my propane systems and everything is going great and the last thing I need is to figure out which components I need for this Humphrey LP light. As you can see in the picture it's missing a few things and i'm pretty new to this so can someone tell me what I need?
Post by vikx on Oct 6, 2015 23:33:02 GMT -8
Not sure from the angles, but you may be missing the ceramic burner nose. If possible, take a photo with the mesh removed.
jerfo
Post by jerfo on Oct 7, 2015 14:12:46 GMT -8
Not sure from the angles, but you may be missing the ceramic burner nose. If possible, take a photo with the mesh removed. here's a better one
Post by vikx on Oct 7, 2015 20:38:40 GMT -8
Yup, does seem to be missing the burner nose. That should screw into the top portion where the gas flows and also allows a mantle attachment.
Missing those parts, I would turn this light into an electric; either 12 volt or 110. Easy to do and no mantles to disintegrate going down the road. Most mantles need replacing every trip.
