Post by Ten on Aug 10, 2015 19:00:28 GMT -8
This may seem silly...but I hate to leave anything so volatile as propane systems unquestioned because it may be silly.... Amongst all the restoration work on the 1970 SC, I decided I would not use the original propane components. Today, the new regulator showed up int he mail so I hurried on down to the exchange store with a couple old empty propane cylinders and got a couple full ones, and proceeded to hook up the new lines. The new regulator is a "Fairview" brand, automatic-changeover model. It seems a bit physically larger than the original, and I suppose an automatic-changeover feature should be expected to be larger that the original regulator. I also added new pigtails, the braided-stainless variety, and a new lead hose on the low-pressure side, leading to the steel pipe below the floor. Now here is where it gets tricky and I feel like I am missing something obvious.... The hold-down for the tanks does not engage the top collar of the tanks correctly, and the regulator seems to be hopelessly wedged between the tanks when it's even close to locked in. Further, if the lock is raised up to latch to the top of the tank collar.... Then the rod is too short. Is this actually too high up to try to engage the tanks anyway, because of the violence of the "ride" when pulling it down the road? Or can I cure this with the most likely cure, a longer piece of threaded rod? Is it that simple or too simple for the Big Brain to figure it out? www.youtube.com/watch?v=isvy_AelUPo
Post by vikx on Aug 10, 2015 21:29:05 GMT -8
I'm thinking a longer rod. Mainly because the regulator isn't fitting and the pretty new pigtails are hitting the tanks when it's lower...
Or, you could add a mounting plate to the existing bracket to raise just the regulator, thus the hoses.
Let us know the end result!
Post by Ten on Aug 11, 2015 15:58:12 GMT -8
@vikx, thank you for the suggestion. Took all day but a solid stand-off looks to be the solution. I started to use a piece of 3/4 plywood, but then thought a 2X4 would be better. The thought process went all the way through "wood will just rot" to maybe buying really long pigtails and mounting the regulator to the tongue frame... I found an old post in my collection of stuff...a 4X4 aluminum clothesline post, 1/4 inch thick, cut it down with the grinder and drilled in some screws, and VIOLA! A bit of overkill I am sure...but it works! Now to anchor the rack down. It was pretty good till the actual weight of tanks on it, and now I am sure the rivets are not going to hold... If it is not one thing it is another dozen...
Post by vikx on Aug 11, 2015 22:54:52 GMT -8
Looks Good! I bolt my tank rack to the tongue. The heads get in the way now and then.
Take a good look, everybody. This is what it means to "make it work". There's always a FIX.
