bimmrr
Proud owner of a yellow and white 62 Shasta Compact
Post by bimmrr on Apr 27, 2015 7:01:16 GMT -8
Hey y'all, Had to replace the rear skin on my Compact so now need to finish the stripping. The stripes on the front and sides are a medium gray/light gray in color, 2 inches wide. Going to use automotive stripping tape and can get a medium gray as well as a silver metallic. Have seen some Shastas where the stripe is actually bare aluminum that has been polished but do not want to get into that. My Compact is yellow and white. What would have been correct if anyone knows ? Thanks Mike
Post by SusieQ on Apr 27, 2015 7:14:47 GMT -8
I believe my '62 stripe was painted silver originally. There was so little paint left on my trailer, it was kind of hard to tell.
Post by nccamper on Apr 27, 2015 7:28:58 GMT -8
Mine was also without paint. I think it looks good as polished metal.
yas
'63 Shasta Airflyte
Post by yas on Apr 27, 2015 8:07:19 GMT -8
The stripe on my '64 Compact was bare aluminum.
Post by SusieQ on Apr 27, 2015 10:54:03 GMT -8
I just assumed my strip paint had had all worn off. It's the only thing I have left to paint and it has to be painted since there's two bullet holes (now filled) in it in the door.
bimmrr
Post by bimmrr on Apr 27, 2015 11:20:59 GMT -8
Thanks y'all ! I would polish it except don't want to get into that much work and maybe mess up my good white and yellow. Sounds like the silver metallic is the way to go ! Regards, Mike
Post by vintagebruce on Apr 28, 2015 4:34:52 GMT -8
My '61 was originally white on white (top and bottom. The stripe (also original) is a dull silver/grey (I'm colorblind), definitely finished in some way, not just bare aluminum.
bimmrr
Post by bimmrr on May 4, 2015 7:07:32 GMT -8
Thought I would post an after thought on this. Bought a 2 inch wide automotive grade stripping tape and it works fantastic. I used what they call silver metallic and looks great. Purchased a 50 foot roll from www.masterstripe.com for $29.00 plus $8.00 shipping and very pleased with results. Have a bunch of different colors available. Easy to apply and a 3M product so you know it is good quality. Regards Mike
