Post by vikx on Jul 21, 2013 22:20:24 GMT -8
Hello all, just wanted to post the correct color code for 7 way connections.
The colors are stamped into the 7 way plug and receptacle. The code below is used for all 7 way wiring.
White=Ground Black=Hot Charge Line Blue=Brake Hot Green=Running and Tail Lights Brown=Right Turn Red= Left Turn Yellow or Center post= Aux
If you are switching from 4 way flat, the code is DIFFERENT:
White=Ground Green=Right Turn...... 4 way Green goes to 7 way Brown Brown=Running Lights..... 4 way Brown goes to 7 way Green Yellow=Left Turn..... 4 way Yellow goes to 7 way Red
Many vintage trailers did not follow the universal wiring code, so you may need to test each wire to see what it does. With a Good Ground, put 12 volts to each wire to see what works.
Note: eTrailer comes up first in any search for wiring codes. The 7 way code on the site is WRONG.
DO NOT USE eTrailer's code when wiring a 7 way system.
Hope this saves some of you headaches when doing tow wiring...
desertman
Post by desertman on Jul 22, 2013 18:25:03 GMT -8
Just had this discussion with my Daughter last night. They were rewiring there trailer (drug the cord). Being a old truck mechanic I wanted to wire it different till she showed me the wiring diagram for the trailer. Thanks for the post
Post by vikx on Jul 22, 2013 22:11:01 GMT -8
You're welcome! I posted this because it is so confusing for people trying to wire their trailers, especially when converting from 4 to 7.
nyredneck
Post by nyredneck on Dec 17, 2014 8:13:22 GMT -8
This is what shows on my 61 Shasta Red green brown and black then a separate black n white and one additional white.
I used a 4 way flat on my jeep connecting to the trailers Green Red and Brown using the conversion of yellow to red and all works. Tail lights tear drops turn signal and brake lights. So my question is what are the other wires for? Black and white almost looks like roamex but I believe is original. Then there is the additional white which looks like a ground. Electric brakes? Anyone have photos of what the original connector end is? Not familiar with what a 7 way looks like.
Post by Ten on Dec 17, 2014 14:08:27 GMT -8
This is the original plug on mine. It is a 1970 Shasta. I think they may have changed the color codes between '61 and '70. But I am not sure of that. I cut the plug loose as I am going to replace it with the 7-pin, to match what my truck is equipped with. I took a battery to the wire ends and found the brown to be the right turn; red is left turn; green is the running and tail lights. There is a heavier blue wire in mine which turns out runs the interior 12-volt lights and water pump; a light-gauge black wire that seems to only run the license light. There are two heavy wires, a black and a white, which short completely dead when I cross either way to the battery, I assume these are for the brakes and indicate that I have a rather large problem to address with the brakes. The lighting fixtures on mine are Reflect-o-lite fixtures. I also have this wiring diagram, which was meant for the older Shastas.... Hope any of this helps.
Post by vikx on Dec 17, 2014 22:14:49 GMT -8
Thanks 10! Test your wiring as above and you'll know which does what...
I'm guessing your extra white is a ground and the other two are brakes. Easy enough to trace them to the backing plates. Most trailer brake wiring is black and white or red and white. Of course the 7 way blue goes to brake hot.
Sometimes you can trace a wire to the frame (GROUND)as well. Easiest wire to identify if it's still connected.
alilbs
Post by alilbs on May 15, 2015 20:57:44 GMT -8
Trying to add a new style 7 way trailer plug on my 58 Shasta. I have yellow, white,green,blue, and brown.where do they go.
Post by vikx on May 15, 2015 21:23:59 GMT -8
Alilbs,
Testing the wires is recommended. Do NOT use your vehicle as a test power source.
Find the ground first. Start with WHITE and see if it goes to the frame or skin anywhere. If it is directly connected to something metal, that's your ground.
The BLUE "might" be electric brake hot. Get under the trailer and see if you can trace to the backing plate. You might have to remove tape to see what wire goes to what.
As far as the other wires, you have to test. Clean the light sockets and be sure the light plates are well grounded before starting.
If you had a 4 way plug on the trailer, I'm guessing:
BROWN is running lights and tails (TM) GREEN is Right Turn YELLOW is Left Turn
To test, ground a portable battery to the trailer frame and lightly touch each wire above to the hot side. Some of the lights should glow if your grounds are good. Label each and go to the next.
For the 7 way connection, you must *change* the color code to today's RV universal code:
GREEN is TM BROWN is LT RED is RT Note the switch on Green and Brown. Red is connected to the 4 way yellow.
Again, Test the wiring before connecting. The above is educated guesses. Hope this helps.
Post by rogerthedodger on May 10, 2016 7:03:06 GMT -8
Thanks to vikx, you saved me a major headache, I was going to use etrailer I had saved. I used your 4 to 7, everything worked first time. Roger
Post by danrhodes on May 12, 2016 7:52:49 GMT -8
I think it is right, Dan. The tail light GREEN just isn't green enough... Wonder if a person could photoshop it?? NOTE: THE ABOVE IS AN IMAGE OF THE VEHICLE SOCKET. It is correct for the 7 way code you should be using and the colors are usually stamped in the plastic on the wiring side. In other words, you can see "green" when inserting the Tail/Marker wire.
Post by vikx on May 12, 2016 11:13:17 GMT -8
Thanks Dan, looks great! (and very green)
Notes:
The middle post (yellow) is for back up lights on modern trailers. It is also labeled Spare or AUX. Basically a seldom used post.
The Black post is 12 volt Hot. It charges the trailer battery when traveling. (fused line from vehicle battery) This Hot post is usually off when the vehicle ignition is off.
Post by danrhodes on May 27, 2016 11:47:11 GMT -8
Btw, here's what's on my truck... The same as the image above.
Post by danrhodes on May 28, 2016 5:49:50 GMT -8
Wonder if we should move this to Tutorials?? Or do you like it here? Seems like a good stickie here to me...
ruderunner
Post by ruderunner on Jan 22, 2017 13:55:04 GMT -8
I think I can explain the different connection in the 7 way plugs. I'm familiar with 2 systems that use the same plug. Semi and RV, the plugs swap but the wires do different things. Being that the semi standard existed before the RV standard, its not surprising that some really old trailers may be wired to that standard.
Inspection and testing is the only way to know for sure.
Also, if you're installing a plug on your tow vehicle, don't assume the manufacturer used RV standard color for the truck wiring. Find a wiring diagram or do plenty of testing. I've had to fix plenty of botched installs over the years.
Note: many pickups and bigger SUV's since the early 2000 have wiring on them for trailer hookups even if the brake control and rear plug aren't present. Pays to look and parts stores may have what you need for a plug in install.
Post by vikx on Jun 12, 2018 19:40:03 GMT -8
[/quote]Is this the factory harness? Chevrolet is usually dead on with there harness. [/quote] This is NOT the universal 7 way RV code. The center pole is always yellow. Green is running lights, red left turn and brown right turn. Even tho today's vehicles don't use these colors, they are wired according to the universal RV code above. The above diagram is using the 4 way color code for the tow wiring.
