Post by mobiltec on Apr 1, 2015 14:13:12 GMT -8
I promised a short video showing the proper use of an air palm nailer when using twisty nails. The heads are round so you must use a pilot hole with the nails because the magnetic hammer doesn't work with round heads. Also you need to control the force of the nailer with the amount of pressure used. For the best control on twisty nails I use about 45 pounds. It's good to experiment with a tool so you get to know how it works in all circumstances.
