Post by vikx on Apr 6, 2018 18:30:43 GMT -8
Not sure on the memory foam overlap but I think it should be at least 3" thick. The problem is WHERE to store it when you are using the gaucho as a coach...
Post by Ten on Apr 6, 2018 19:04:29 GMT -8
I push mine up and use it as cover for the seat cushion, with the "back" part slid up the wall. It gets in the way of the side window and would do the same with the rear window in the Airflyte. Could probably fold it over and throw it just over the seat part, but I like to keep it out flat.
speak
1959 Shasta Airflyte
Post by speak on Apr 9, 2018 16:34:06 GMT -8
Thanks for the ideas. I'll ponder the idea some more and keep you all posted.
