Post by wisconsinjoe on Jan 17, 2015 16:19:37 GMT -8
Don't know where to put this thread, because it fits both inside and outside. We have a short door and a dropped floor in our Friendship Vacationaire. I can't tell you how many times I thwacked my noggin going in and coming out of that darn door. Once inside, there is a little stoop then a drop down of 9 inches. I have hit my head so hard on the 5 foot door, that I then fell into the dropped floor. On the way out, even though you KNOW that door is there, it is even easier to hit your head because you are rising up from the dropped floor. Adding in a few beers does not help matters. After one camping trip where I hit my head THREE TIMES (once while trying to burp my infant grandson), I ended up with a nice bleeding wound on my bald head that didn't look any prettier with a a bandage on it. Something had to be done. And wearing a Green Bay Packers cheese hat was NOT the solution. I removed the top plywood trim piece, curve-shaped a poplar board in that profile, and glued on a piece of dense foam (from a section of flooring stress mat). It was sized so the foam came just below the aluminum screen door to provide soft protection when entering as well as leaving. I predrilled screw holes that I re-located after the foam was glued on by poking an awl hole big enough for a screw driver. You cannot believe what an improvement this has been.
Post by kirkadie on Jan 17, 2015 18:21:56 GMT -8
Post by wisconsinjoe on Jan 17, 2015 20:13:30 GMT -8
kirkadie,
That is VERY funny. Also, I kind of want that first one, but with only 13 hours left and 4 bids, I'll have to pass.
Post by mobiltec on Jan 26, 2015 12:23:22 GMT -8
We have had problems like this getting in and out of airplanes in skydiving. We found that putting something soft like what you have installed is even more dangerous than a bump on the noggin. That's because when you do hit it, instead of your hard head glancing away from the hard object, it becomes temporarily lodged in the soft protective pad that you installed which causes sometimes major damage to your neck vertebras. You could even fracture them. I would either learn to enter and exit safely without bumping your head or get rid of the trailer. Might save you a lot of future pain that will be very difficult to get rid of. Neck injuries are many times permanent.
lakewoodgirl
1954 Lakewood
Post by lakewoodgirl on Feb 17, 2015 11:42:32 GMT -8
wisconsinjoe LMAO! I'm a Floral Design Float Supervisor for one of the Float Builders for Rose Parade, I'm going to recommend that they do this to all the scaffolding! Lost count on how many times I've bumped my head. This year was a doozy. Stood straight up and hit my head while standing on a 2.5' wide plank 21 feet up in the air. Yep. Had a mild concussion this time. But, kept on working, these floats don't finish themselves!
