Post by mobiltec on Oct 5, 2014 8:51:59 GMT -8
You'll be able to tell if the metal is too corroded to withstand bending back flat. And if it is, you needed a new roof anyhow. I have some photos of what happened when I did it that I can show you and will do so tomorrow. Too late tonight to go get them... Well, the wife has pushed a stroller into the back and the toddler smashed the door into the side...the metal just bent, so I'm hopeful. I look forward to your photos. OK here ya go. This is a 1954 Aljoa. This example is the worse that I have seen in this regard and right away I knew I needed a new roof. But it rolled up really nice once the edges were bent out flat. And they don't have to be completely flat to roll the material up. Just almost flat.
