Post by universalexports on Jul 7, 2013 17:41:33 GMT -8
I am almost ready to glue my tiles in place, does anyone have a recommendation for a good glue? I went to Lowes today and they had some Commercial VCT adhesive, will that be OK, or is there something a lot better? thanks
gonekayaking
1956 Shasta 1500
Post by gonekayaking on Jul 9, 2013 8:56:52 GMT -8
That's the stuff I used....had to buy a large can which seemed a bit wasteful. Make sure the get the right notch trowel to use and wait for it to dry clear before adhering the tiles.
Post by kto17 on Jul 9, 2013 10:44:24 GMT -8
Use the tile manufacturer's adhesive if you can, and as stated above make sure you use the right size trowel. They are not all the same. Too much adhesive is very bad and dimples will show up in the tiles from small point loads even with very little weight. Follow the adhesive directions exactly.
Post by universalexports on Jul 9, 2013 14:55:18 GMT -8
thanks, I think i got the right trowel, (the small notched one) it has 1/16 long point with 1/32 groove or something like that.
Post by kto17 on Jul 9, 2013 15:46:50 GMT -8
Trowel size depends on the adhesive.
Post by universalexports on Jul 9, 2013 16:36:25 GMT -8
Trowel size depends on the adhesive. yeah, the adhesive had the reccomended trowel size on the side, the numbers didnt exactly transfer over to their trowels, the numbers were in a little different order??? but should work, here are pics
bricklayer
Post by bricklayer on Jul 9, 2013 19:22:21 GMT -8
That is the adhesive I used also. Strong stuff. If I would have known I could have sent you the 2/3's of a tub I have left over. It comes in two sizes, too much, and way, way too much. :-)
Ben
