shastajeff
1965 Shasta Compact - "Stu"
Post by shastajeff on May 23, 2014 5:48:59 GMT -8
Ever gone camping and forgot to bring a Brillo pad to clean the grill? I use a tripod to cook over the fire. I always forgot to bring a Brillo pad so I would try to burn off the residue over the fire. That just seems to leave a burnt residue. Then I learned about using a piece of crumpled aluminum foil to clean the grate. It actually works better than a Brillo pad. Give it a try the next time you go camping. You will be amazed.
Post by Ross on May 23, 2014 6:14:12 GMT -8
I always bring a wire brush with us. It's part of our dutch oven and grilling tote box. BUT, I will try the aluminum foil trick the next time we are out on a trip.
Thanks for sharing!
