Post by nccamper on May 11, 2014 22:17:22 GMT -8
Our new Shasta has only one of these. Should there be more? Where does it go if it spans both sides? Does anybody have a photo of the compact bed fully set up with the table down?
Post by SusieQ on May 12, 2014 6:51:10 GMT -8
There should be two, one for each side. The bed pulls out and the frame sits in the notch with the cross part on the floor. With the table set up, the bed pulls out almost to the table leg on each side.
Post by SusieQ on May 12, 2014 6:53:11 GMT -8
Btw, there was someone at the rally who had an extra set of the legs that she wanted to part with for shipping costs.
Post by nccamper on May 12, 2014 8:27:23 GMT -8
Btw, there was someone at the rally who had an extra set of the legs that she wanted to part with for shipping costs. Do you have a name and number? I'll call her.
Post by SusieQ on May 12, 2014 8:38:10 GMT -8
Sending you a pm.
luvinature
1951 Flying Cloud
Post by luvinature on Jul 11, 2015 18:21:34 GMT -8
Would this be the same for a 69' compact ? Just got it and we were wondering why the legs were short. I guess these pieces were missing, is that correct ? If so is there anyone who can get me dimensions so I can have them made. Thanks from a newbie !
Post by SusieQ on Jul 11, 2015 19:47:51 GMT -8
Would this be the same for a 69' compact ? Just got it and we were wondering why the legs were short. I guess these pieces were missing, is that correct ? If so is there anyone who can get me dimensions so I can have them made. Thanks from a newbie ! Are your benches in a U shape with one across the back and two small on the side or do you just have two, one on each side? My 65 with the U shaped benches pull out from the back and the legs are attached. I think the legs are attached with both styles 65 and later.
luvinature
1951 Flying Cloud
Post by luvinature on Jul 11, 2015 20:01:41 GMT -8
Would this be the same for a 69' compact ? Just got it and we were wondering why the legs were short. I guess these pieces were missing, is that correct ? If so is there anyone who can get me dimensions so I can have them made. Thanks from a newbie ! Are your benches in a U shape with one across the back and two small on the side or do you just have two, one on each side? My 65 with the U shaped benches pull out from the back and the legs are attached. I think the legs are attached with both styles 65 and later. I have two beds on one each side. The legs are too short and we don't know if the PO cut them down or if we're missing something.
Post by nccamper on Jul 12, 2015 6:18:55 GMT -8
I have two beds on one each side. The legs are too short and we don't know if the PO cut them down or if we're missing something. Do you have a photo you can share?
Post by mel on Jul 13, 2015 18:33:03 GMT -8
Our new Shasta has only one of these. Should there be more? Where does it go if it spans both sides? Does anybody have a photo of the compact bed fully set up with the table down? Are you looking for photos of the old or newer model compact?
Post by nccamper on Jul 14, 2015 4:47:20 GMT -8
The one in the photo is for a 1962 Shasta Compact. I'm not sure what the newer ones look like.
Post by mel on Jul 14, 2015 5:15:59 GMT -8
Is the a photo of what you need? if not let me know and I can run out and take what ever photos you need Looks like it is the middle leg of the bench
Post by nccamper on Jul 14, 2015 10:11:44 GMT -8
Mel, you have a first Generation Compact. The leg in the photo above fits your bed but I'm not sure about a 69.
My guess is if the supports are too short, they are not for the later Compact.
I'm not a big fan of how our 62 Compact bed pulls out and is supported. It worked, but a little clunky. Not very smooth.
Post by SusieQ on Jul 15, 2015 3:30:46 GMT -8
The second gen Compacts have the legs attached to the frame.
Post by nccamper on Jul 15, 2015 5:21:20 GMT -8
The second gen Compacts have the legs attached to the frame. That makes more sense than the floating leg. Which do you like better? I ask because I know you collect Compacts.
