fargo
Post by fargo on Apr 23, 2014 19:39:52 GMT -8
fargo
Post by fargo on Apr 23, 2014 19:43:13 GMT -8
fargo
Post by fargo on Apr 23, 2014 19:44:21 GMT -8
fargo
Post by fargo on Apr 23, 2014 19:45:12 GMT -8
Is there a way to put multiple picture in the same post ?
Post by ladywendolyn on Apr 23, 2014 20:19:51 GMT -8
Just keep using the photo link tool. Don't hit post until you have them all on your message.
fargo
Post by fargo on Apr 24, 2014 18:37:46 GMT -8
Can anyone identify this trailer there is no id plate anywhere there is no numbers on the frame , or in the door jam area. ,no info on the inside of any cabinet.
Post by SusieQ on Apr 25, 2014 9:53:17 GMT -8
Not a clue, but you sure do have an awesome tow vehicle!
Post by ladywendolyn on Apr 25, 2014 11:23:30 GMT -8
The tin can tourist Facebook page, has a lot of members. If you don't get an answer here, someone on there may recognize it and TCT has a database of info on a lot of old trailers. Plus there is some sort of vintage trailer museum in the isa and they keep records
Post by SusieQ on Apr 25, 2014 13:00:42 GMT -8
fargo
Post by fargo on Aug 11, 2014 10:13:13 GMT -8
Ok I finally hound the manufacture , it's a RedWing appearantly they where made in Canada I still don't know the year of it, I looked all over the frame but I cannot find a serial number anywhere , got the camper in the garage and started pulling all the front tin off to assess the water damage and wood rot so far it doesn't look that bad for the age of it,
fargo
Post by fargo on Aug 11, 2014 19:15:16 GMT -8
Found out more info it was manufactured about 70 miles away between 1957-1963 according to an ex employee in Brandon Manitoba I am trying to track down the family to see if they have any info , Manufacture was Redlick Trailer Co.
Post by vikx on Aug 11, 2014 21:15:02 GMT -8
Really like the pattern! It looks like a Red Wing. Thanks for the updates.
fargo
Post by fargo on Aug 23, 2014 16:44:12 GMT -8
Got the RedWing brought into the shop , started to examine the damage from all the years ,I started pulling off the exterior tin to get a better view .here is a picture of the damage and the tear down process has just began wish me luck .
fargo
Post by fargo on Sept 1, 2014 19:36:12 GMT -8
Got all the tin off and the manufacture of the trailer used every little scrap piece of insulation think they had left over . The trailer appears to be built like a mobile home walls on top of the floor , so it looks like a full gut job all I got left is the two side walls that will be coming off and I will use them as a pattern to make new walls , it's been quite the tedious process to avoid the walls from falling apart into a pile of rubble .
fargo
Post by fargo on Oct 2, 2014 20:14:11 GMT -8
