Post by vikx on Apr 11, 2014 21:56:54 GMT -8
Cheri, your ideas and willingness to try are amazing. Take some time to slow down and do a little research before starting in.
The rafters will probably not "pry" loose without breaking. The way these trailers were made dictates the way you take them apart.
A new roof isn't impossible for one person. If you have a friend to help at times, that's all you'll need. Most of it can be done by yourself. These little trailers take some time, but you CAN DO THIS.
coloradoan
1959 Shasta Airflyte 16
Post by coloradoan on Apr 26, 2014 18:32:36 GMT -8
I was wondering about painting some kind of goop on the seams on the UNDERside of the roof while it is hoisted in the air off the trailer? My roof has never leaked but mobiltec got me concerned that just the jostling of removing the roof would possibly create a leak. Since I don't want to paint goop on the outside (it has never had goop on it), I thought "Why not on the inside"? Is there a reason NOT to do this?
Post by SusieQ on Apr 26, 2014 18:58:47 GMT -8
I would suggest what Vikx suggested to me and that is an aluminum waterproof tape for the underside. Check at Home Depot or Amazon. Lowe's has a different brand but I can't vouch for it. Polyken/Nashua 361-11 Waterproofing Repair Tape is a tape with an aluminum foil backing/carrier which is coated on one side with a permanent butyl rubber adhesive
Post by SusieQ on Apr 26, 2014 19:27:55 GMT -8
I don't think putting a strip of foil tape on the inside of the seam will hurt anything, it may not help, but it won't hurt. And it won't stick in your hair. The sticky part is covered with aluminum that is fairly thick. It's an easy, neat application.
Post by mobiltec on May 10, 2014 20:36:20 GMT -8
As long as you don't kink or dent the seams it should be fine. But I do like the idea of the inside taping of the seams. I may do that on an Aljoa that's coming in. Just to help make sure.
Post by vikx on May 10, 2014 22:47:22 GMT -8
The best waterproofing tape was Shurtape brand but has been discontinued. The Nashua above is nice and sticky and is fairly thin so doesn't interfere in tight areas. I like the idea of extra insurance.
Post by SusieQ on May 11, 2014 6:49:27 GMT -8
Post by John Palmer on May 11, 2014 9:16:19 GMT -8
I plan to "check my new roof for leaks", in SIXTY YEARS, 2074!
I think that having a reason to hang around, might keep me going for a while longer.
Post by mobiltec on May 11, 2014 9:29:10 GMT -8
I plan to "check my new roof for leaks", in SIXTY YEARS, 2074! I think that having a reason to hang around, might keep me going for a while longer. I can't see taping or sealing the inside or outside of seams on a new roof. But tape on the inside of an old one isn't a bad idea just to make sure.
Post by vikx on May 13, 2014 21:35:18 GMT -8
Yup, but it's "currently unavailable" and I believe Shurtape quit making it... Can't find it. Even the Shurtape site comes up with nothing with a search for "waterproofing repair tape". I'm wondering if the butyl mastic tape is a replacement?? I do like the Nashua, as I said, it is thin and doesn't add bulk...
Post by SusieQ on May 14, 2014 3:42:52 GMT -8
Our Lowe's has it in there store! It may disappear once they sell it all. I used the Nashua, ordered it online from Amazon.
