dawn
Post by dawn on Feb 14, 2014 4:19:13 GMT -8
Thanks for the measurements! I'm excited to see your renovation start to evolve.
Post by mobiltec on Feb 14, 2014 7:38:27 GMT -8
Thanks for the measurements! I'm excited to see your renovation start to evolve. I've been kinda stuck on this 57 Westerner because the owner decided to do more work but I'm just about finished and will be back on the 59 Shasta soon.
Drake
'59 Shasta AirFlyte
Post by Drake on Feb 14, 2014 12:11:42 GMT -8
Thanks Soup. I was thinking somewhere in the $500 range give or take $100. So I wasn't too far off. I'm closer to California than you so hopefully shipping will be less. Thanks fo the links to your project trailers
Post by universalexports on Feb 14, 2014 19:48:15 GMT -8
nice, I have it's twin!
lamacki1
1957 Shasta 1500 - Sundance
Post by lamacki1 on Feb 16, 2014 8:39:48 GMT -8
Very nice find...and so close to you! Just shows how you never know and you have to talk to everyone! It's a keeper for sure.
Barbara
Drake
'59 Shasta AirFlyte
Post by Drake on Feb 17, 2014 8:48:28 GMT -8
So when the exterior has been hand painted with a brush and roller is it better/easier to remove the paint from the j-metal and awning rail before or after you take it off the trailer?
Post by mobiltec on Feb 17, 2014 11:12:45 GMT -8
It's not easy either way. I would say get as much off as you can while it's on the trailer. I use a wire wheel brush on the drill motor and then you can either paint it later or leave it with the bright satin finish that the wire brush leaves.
Post by vikx on Feb 17, 2014 21:16:21 GMT -8
I take my J rail off to strip it. Hang it over a couple of saw horses (or 3 if it's way long) and strip away. I use the poisonous stuff that works; it's water rinse-able. Works for me...
Drake
'59 Shasta AirFlyte
Post by Drake on Feb 17, 2014 21:24:45 GMT -8
I take my J rail off to strip it. Hang it over a couple of saw horses (or 3 if it's way long) and strip away. I use the poisonous stuff that works; it's water rinse-able. Works for me... Does the poisonious stuff have a name?
Post by vikx on Feb 17, 2014 21:29:20 GMT -8
LOL. Jasco or Klean Strip Gel. Just regular ol' paint stripper. Some people like the citrus stuff, but it takes a lot longer to work.
dawn
Post by dawn on Feb 18, 2014 17:30:06 GMT -8
First a disclaimer. I'm a total newbie to the trailers and so far we've managed to make every typical newbie mistake there is. But I've stripped paints and finishes for years on old buildings. I like stripper better than sanding because of the lead abatement issues in old paint. I think it's harder to contain the dust from sanding than the icky mess from the stripper. I use both kinds, and the citrus sometimes will work better than the kleenstrip though you do need to give it time and it can't be too cold. BUT I'm really not sure about the products used on these old trailers though. If you need to get paint off hinges or drawer pulls, boil em in a pan of water with some baking soda and it just lifts right off like magic. And I'm not sure about shellac but if it is similar to lacquer, it will come off quick and easy with lacquer thinner and steel wool.
Post by mobiltec on Feb 18, 2014 18:54:58 GMT -8
If it's shellac you use Denatured Alcohol...
Drake
'59 Shasta AirFlyte
Post by Drake on Feb 19, 2014 8:00:44 GMT -8
I tried the wire wheel on a drill for the curbside. It worked well except in the nooks and crannies. I'm going to try the stripper on the street side.(no pun intended)
Post by mobiltec on Feb 19, 2014 8:08:17 GMT -8
You will need to remove the J Rail to get the nooks and crannies. But it's flimsy and harder to deal with when it's off the trailer. We are doing that today as a matter of fact. I use the chemicals first, then the wire wheel where I can. Then the J Rail comes off and the rest is done with chemicals again along with a small hand held wire brush that looks like a tooth brush.
Post by Hamlet on Feb 19, 2014 17:32:08 GMT -8
If it's shellac you use Denatured Alcohol... Actually, any kind of 70% alcohol will work. Got any 140 proof rotgut sitting around? It'll dissolve that shellac right away and leave an odor that the Highway Patrol will be able to pick up from about a mile behind you.
