59deluxe
Post by 59deluxe on Jan 30, 2014 21:08:50 GMT -8
New formica and aluminum trim, old sink needs a couple of chips repaired
59deluxe
Post by 59deluxe on Jan 30, 2014 21:12:07 GMT -8
New cabinet and new countertop-could not find the color we wanted in the original linen pattern, so we used kind of a s pattern.
59deluxe
Post by 59deluxe on Jan 30, 2014 21:13:51 GMT -8
Looking at the curbside cabinet- turned into quite a job building this one.
59deluxe
Post by 59deluxe on Jan 30, 2014 21:15:46 GMT -8
Looking from back to front, have the new dinette bases started. Can see what the stove looks like when finished- looking more and more like a camper
59deluxe
Post by 59deluxe on Jan 30, 2014 21:20:45 GMT -8
Better picture of the stove and cabinet, installed the original faucet. Will put the inserts into the stove knobs later.
59deluxe
Post by 59deluxe on Jan 30, 2014 21:22:24 GMT -8
Drivers side back corner, have the ceiling started- this will test your patience.
59deluxe
Post by 59deluxe on Jan 30, 2014 21:25:04 GMT -8
Curbside outside rear corner, can see the 4" rear bumper we added.
59deluxe
Post by 59deluxe on Jan 30, 2014 21:34:29 GMT -8
Looking from front to back, ceiling over large cabinet. When i rebuilt the cabinets, I used the original round corners and covered them with new veneer. Used all solid ash and plywood, will make the trailer a little bit heavier. Used all new rubber welting between cabinet, floor and ceiling.
59deluxe
Post by 59deluxe on Jan 30, 2014 21:37:02 GMT -8
Looking down on top of bathroom wall, welting is done and ceiling is ready to be put on.
txoil
1960 Shasta Deluxe 19
Post by txoil on Jan 31, 2014 3:38:36 GMT -8
Wow...you have achieved a LOT of progress already! Thanks for sharing with us. One question though, why did you select the ash panels? Do you just like the look of ash over birch?
59deluxe
Post by 59deluxe on Jan 31, 2014 7:17:11 GMT -8
This one came with an ash interior. I think it depended on where it was built on whether it had ash or birch.
Post by mobiltec on Jan 31, 2014 7:34:21 GMT -8
This one came with an ash interior. I think it depended on where it was built on whether it had ash or birch. What it depended on was whether they had access to birch or ash at the time. Sources of birch were becoming more limited due to the expansion of the trailer industry and when they couldn't get birch, they would use ash and sometimes maple.
Now it is illegal to transport ash in the US due to a bug called the "Emerald Ash Borer". More Info here... www.emeraldashborer.info/faq.cfm#sthash.W2EMuggZ.dpbs
Many infestations, however, were started when people moved infested ash nursery trees, logs, or firewood into uninfested areas. Shipments of ash nursery trees and ash logs with bark are now regulated, and transporting firewood outside of the quarantined areas is illegal, but transport of infested firewood remains a problem.
Although it can be bought in certain areas where it is grown and milled it can not be transported to other places where it isn't grown and milled. So the sources are very limited now.
59deluxe
Post by 59deluxe on Jan 31, 2014 8:05:54 GMT -8
This one was built in Van Nuys California, I had read somewhere that the Indiana trailers usually had birch and the ones from California had ash.
Post by mobiltec on Jan 31, 2014 13:56:04 GMT -8
With the 1960 and newer Shastas I've seen both here in California. But the older ones that I've seen were mostly birch except for this 59 I'm working on LOL. And I can't get Ash for it. The 57 Westerner I'm working on is also Ash and I used White Oak 1/8 inch to replace panels with. It has a very similar grain pattern.
Post by vikx on Jan 31, 2014 19:50:09 GMT -8
Very nice 59! Jealous of your veneer. Mine rippled and not sure why. Congrats!
