Post by mobiltec on Aug 14, 2023 7:53:21 GMT -8
FRP or Fiberglass Reinforced Plywood will cost a chunk also. I would stick with aluminum. One of the bad things about FRP is that it tends to delaminate over time from the plywood. Then it looks horrible and there is no repair. Again. Stick with aluminum. Yes it's expensive. What isn't today???
alexrepair
1970 Scotsman Model 1500
Post by alexrepair on Aug 16, 2023 8:32:08 GMT -8
Roof Roof Roof Updates Glued and on place
Ends
I sanded all corners
It is time for roof wiring
Something like that on picture
By the way those exterior cabinet screws holding awesome
Prtedrilled with 1/8 bit
Screwed into 1/2 plywood
No way to pull out
Special thank for advise for using this screws
Post by vikx on Aug 16, 2023 10:57:33 GMT -8
It's really looking good!
Post by nccamper on Aug 17, 2023 16:11:45 GMT -8
It’s nice seeing the kids helping.
alexrepair
Post by alexrepair on Aug 19, 2023 23:29:29 GMT -8
On a trailer there are spots where trailer marker lights should be placed.
They should be screwed to some sort of strong base. Here is what I did: Cut the 1" x 2" (actual 3/4 X 1" and 1/2" ) around 8 inch long. Cut one side of them with 5 degree angle. Temporally screwed for screws ( for supporting wire ) and glued planks together and to the plywood behind them. The wire helps to keep them in place.
Post by Teachndad on Aug 20, 2023 4:21:40 GMT -8
Hi Alex,
The word that describes your build is Resourseful.
I like how you did your backer board for the marker lights on that front curve.
Cheers,
Post by vikx on Aug 20, 2023 10:39:10 GMT -8
I like the idea of wood backers for the lights. Be sure to groove for the wires and maybe a hole behind the light for tucking them. I like to connect my lights with tiny wire nuts, so need a space behind the light.
Also, I think some sort of tape over the edge wood would protect your metal from the screw heads. Aluminum loves to react with other metals.
alexrepair
Post by alexrepair on Aug 29, 2023 21:16:39 GMT -8
Here are some updates Roof insulation and foam to fill the gups Back board to hold back top tail lights Sealed al around exterior wood Additionally, paint some rubberized coat around every corners
alexrepair
Post by alexrepair on Aug 29, 2023 21:26:13 GMT -8
Some insulation on sides , back and front Aluminum top is going on it's place
Stapled at front
And pulled on back to stratch
Post by vikx on Aug 30, 2023 15:17:11 GMT -8
Great pictures!
alexrepair
Post by alexrepair on Aug 31, 2023 23:43:21 GMT -8
First time I stretched the roof skin back, I figure out that the hole for top for roof ventilation didn't fit correctly. It should be 3/8 toward the front. So I stapled the front wrongly/lose. I need somehow to staple correctly at the front. For that I take out all staples and did this: I screwed a 2 by 6 at the appropriate level to two planks. Used three straps to tie the front of the skin to it's place above front windows, stapled, and stretched on back. Now the opening on top for the fan/vent is inline to the right place. Time to place aluminum side pieces. Here is a temporary wooden holder. It holds this long pieses and easyly can be lifted at the right level with angle wooden sticks I kept from the time I did roof rafters from 2X4 wood. Time for the second piece: Have fun to everybody who is restoring trailer right now! How many of you are doing it right now? And have the same project you are involving in. Oh we just switched to month of September 2023? Sorry if I am asking for too much. Alex Whatever you do, work at it with all your heart, as working for the Lord, not for human masters Colossians 3:23-24 NIV
Post by mobiltec on Sept 1, 2023 11:33:24 GMT -8
A little backwards but what ever works I suppose. We usually put the wall metal up first and then put the roof with the fold over on afterwards. But she's looking good. We'll have to let the test of time tell us if sealing the plywood works. There are pros and cons to that.
alexrepair
Post by alexrepair on Sept 1, 2023 20:46:40 GMT -8
alexrepair
Post by alexrepair on Sept 6, 2023 23:12:57 GMT -8
We where on outside walk. I looked at weather app and there 20 minutes before rain starts in our city.
Trailer was covered just on time!
alexrepair
Post by alexrepair on Sept 6, 2023 23:24:03 GMT -8
Today was a big day!!! With son's help it happened.
Look before and after IWe painted the same color as it was original. Just shoot a coat of texture on 1/5 height from the bottom. There were so many in-perfections. We straitened the most dents on side metal. Now thinking about do we want a different color paint lines on middle or something. Looking through the web for ideas... Blue line to match the frame color... or different shape... angles
