tincanalley
1958 Jewel
Post by tincanalley on Mar 17, 2023 14:12:12 GMT -8
Finally getting to cutting the ply for the floor. Next steps to fit the wheel wells under the Masonite next to the frame, attach from the underside (this was an original factory design - not easiest install fastening the sheet metal to the wood floor frame and sandwich between that and the metal frame). Make sure the wall well cut outs line up, scribe a cut out or the wheel wells etc… lots of walls up and down to dry fit, before attaching the floor frame to the chassis. The 45 angle bevel edges at the front and back turned out pretty good. Now for the cabinet rebuilds… 80319EBC-6186-4BD5-A7D8-265114FB87E1 by asmay22, on Flickr C7F0A137-32EC-445A-801E-DCBE377634EB by asmay22, on Flickr 006862D3-D327-4163-BF37-48029B6513E5 by asmay22, on Flickr
tincanalley
1958 Jewel
Post by tincanalley on Mar 18, 2023 14:22:44 GMT -8
62jewel
Feeling a bit hammy!
1963 Jewel
Post by 62jewel on Mar 20, 2023 9:24:32 GMT -8
Looking good. Did you have to pay extra to get a model to hold up your side for you?
tincanalley
1958 Jewel
Post by tincanalley on Mar 20, 2023 13:19:45 GMT -8
Ha! No extra charge. The only labor I can afford (free)!
tincanalley
1958 Jewel
Post by tincanalley on Jun 14, 2023 21:55:31 GMT -8
Finally got the floor frame bolted to the chassis, wheel wells fastened, and the plywood fastened to the floor frame. All ready for marmoleum sheet, after some Henry’s filler prep. IMG_2135 by asmay22, on Flickr
Post by mobiltec on Jun 23, 2023 13:07:40 GMT -8
You're getting there.
tincanalley
1958 Jewel
Post by tincanalley on Jul 10, 2023 19:41:52 GMT -8
Just getting to the cabinet design and layout which brings up a few questions:
1.). The walls go on top of the floor not the sides. Should I put the walls over the marmoleum or walls first then flooring? Not sure it makes that much difference…opinions?
2.). Since I’m rebuilding all the cabinets, I was going to shorten the wardrobe cabinet by about 4 inches. From 32 1/2 to 28 1/2. Also shortening the kitchen cabinet to match. This is to accommodate a 53” wide bed vs 48”. Has anyone done anything like this? Actually, we can both fit on a 48” I think we will probably stick with the 48x 74 they are on sale, basically going on the trailer trash to treasure recommendation. Never mind I guess…
Thanks
newin62
1962 Shasta Airflyte
Post by newin62 on Jul 11, 2023 2:35:13 GMT -8
1.). The walls go on top of the floor not the sides. Should I put the walls over the marmoleum or walls first then flooring? Not sure it makes that much difference…opinions? I don't have any experience with walls on top but Marmoleum is a bit tricky to install if you haven't done it before. I think it would be much easier to install with no walls in the way, especially if your Marmoleum is in sheet form. Peter
Post by Teachndad on Jul 11, 2023 6:36:16 GMT -8
I agree with Peter. It's just so much easier without having to go around the cabinets. That's how it was originally built.
Marmoleum down and then cabinets and walls on top. It was faster, easier this way. Faster meant less cost to the factory to pay in labor costs, too.
Marmoleum is expensive. If you want to guarentee that you can apply it without any mistakes which could be very costly, maybe consider having someone apply it that has experience. It might be money well spent.
Getting around the wheel wells could be problematic.
Cheers,
tincanalley
1958 Jewel
Post by tincanalley on Jul 11, 2023 7:59:21 GMT -8
Thanks guys. I’m going to build a template and cut to that, and put it all down while there’s nothing in the way. Now walls or cabs. It’s a sheet.
tincanalley
1958 Jewel
Post by tincanalley on Jul 16, 2023 6:52:27 GMT -8
Finally gluing down the marmoleum…. I’ll be trimming the edges after the glue dries. I’ll post a pic of the final flooring. We are off for a 3 day bike ride! Each little bit gets me inspired to finish… IMG_0321 by asmay22, on Flickr
Post by mobiltec on Jul 17, 2023 17:02:34 GMT -8
I always put the flooring down first. Them mount walls on top. Did that with my Jewel. And that's the way the manufacturers do all of them.
tincanalley
1958 Jewel
Post by tincanalley on Jul 20, 2023 17:14:58 GMT -8
Finally. Floored glued down and trimmed. On to the cabinets and wrap. IMG_2189 by asmay22, on Flickr
Post by Teachndad on Jul 20, 2023 22:12:32 GMT -8
It's looking good. I was poking around your Flickr album and found this photo. I love those right angle clamps. You did a very nice job on you walls. Nice butt joints too on your wall! Cheers, Rod
tincanalley
1958 Jewel
Post by tincanalley on Jul 21, 2023 7:10:42 GMT -8
Thanks Rod,
It’s been a slow journey…hoping to make more progress this summer.
