andrew
Post by andrew on Jan 27, 2020 16:42:28 GMT -8
Need help finding parts for a 1973 alpine sprite. Really not sure if that is correct year. It has a split door and propane lanterns in side , they are original. Thanks for the help
Post by nccamper on Jan 27, 2020 18:59:57 GMT -8
I've bought parts from a member who goes by trailertrasher but he hasn't been on lately. Mobiltec has his email. Hopefully he will chime in.
Post by vikx on Jan 27, 2020 22:11:12 GMT -8
Trailertrasher1@gmail.com
Post by mobiltec on Jan 28, 2020 6:30:58 GMT -8
Chiming in. Yep. trailertrasher1@gmail.com Tell Chris what you need. He may have it. If he doesn't he will probably keep an eye out for it. What parts are you looking for?
andrew
Post by andrew on Feb 4, 2020 9:51:11 GMT -8
Thank you all for the response! I am looking for window and door gasket, jack and hitch assembly. Andrew
justriley
Post by justriley on Feb 5, 2020 12:41:21 GMT -8
Hi, not sure if you’ve seen , but Home Depot sells classic jalouise however you spell it windows , that may fit. Lowe’s also , hope it helps . They are not classic but still from the era structurally, but not exactly the same . Still worth checking out as you can return them , if any problems occurs.
andrew
Post by andrew on Feb 14, 2020 15:00:51 GMT -8
Had anyone heard of a alpine sprite? 1968-1973
Post by nccamper on Feb 14, 2020 15:46:54 GMT -8
No, do you have a photo?
andrew
Post by andrew on Feb 14, 2020 16:04:04 GMT -8
Yes, trying to figure out how to post it
