Thubb4
1978 Terry Taurus
Post by Thubb4 on Oct 27, 2019 12:37:53 GMT -8
Do I need to replace the entire line or can i cut the line and add some kind of a adapter to fix this issue? <a href="https://s1079.photobucket.com/user/thubb4/media/gas%20line_zpsa6to36p8.jpg.html" target="_blank"><img src="https://i1079.photobucket.com/albums/w503/thubb4/gas%20line_zpsa6to36p8.jpg" border="0" alt=" photo gas line_zpsa6to36p8.jpg"/></a>
Post by kirkadie on Oct 27, 2019 13:49:35 GMT -8
I can only say I've been taught that the fewer joints the better. Others say the old original lines are so much higher quality than what you'll get these days at a big box.. Was that damaged during a restore. Is the rest of the line visible and testable?
Thubb4
1978 Terry Taurus
Post by Thubb4 on Oct 27, 2019 13:57:45 GMT -8
I have not tested the lines yet. I discovered this yesterday after removing the kitchen cabinet.
Post by vikx on Oct 27, 2019 23:01:33 GMT -8
That looks like a water line. Propane lines rarely split like that, in fact, I've never seen it. Trace all your copper lines and be sure which is what. If it's a water line, replace with Pex.
Yes, you can splice that line. Cut the line back until there is a nice round tubing. Flare the line with a 3/8 nut on both ends and add a "union". That will make the splice. You may have to have a short tube extension depending on the damage extent.
Thubb4
1978 Terry Taurus
Post by Thubb4 on Oct 28, 2019 15:06:29 GMT -8
It is the propane line that was connected to the oven.
Post by vikx on Oct 28, 2019 20:29:55 GMT -8
Did the propane line go up and into the stove top manifold or is it a separate oven? You've got my curiosity up now...
Thubb4
1978 Terry Taurus
Post by Thubb4 on Oct 29, 2019 20:15:48 GMT -8
Did the propane line go up and into the stove top manifold or is it a separate oven? You've got my curiosity up now... Yes. The stove and oven are 1 unit. <a href="https://s1079.photobucket.com/user/thubb4/media/20190816_194714_zpsxf0dzfiq.jpg.html" target="_blank"><img src="https://i1079.photobucket.com/albums/w503/thubb4/20190816_194714_zpsxf0dzfiq.jpg" border="0" alt=" photo 20190816_194714_zpsxf0dzfiq.jpg"/></a>
