kwaggs
Post by kwaggs on Dec 16, 2013 17:56:42 GMT -8
So I received an ad from Harbor Freight and on the ad it had a CEN-TECH 2000 WATT Continuous/4000 WATT Peak Power Inverter for $129.99, Im not even close to the wiring stage of our build but I was thinking this would be a good purchase to prepare for that phase of our Shastaration. Has anyone ever used this brand and Im not sure but I think it will have enough wattage to supply juice for our fridge, coffee maker, a few LED lights and stereo. Im not an electrician by any means but I will do the research and I will make the proper wiring upgrades and use the correct gauge wires. Any thoughts on this size and brand Inverter???
Post by SusieQ on Dec 16, 2013 18:11:02 GMT -8
Kwaggs, I don't have that brand but I have a a Peek 2000 watt with 4000 peak, almost twice the price at advanced auto. I bought it specifically for using with my dorm fridge when I traveled this past summer. And yes, it will run the fridge, BUT the problem I encountered was that the fridge pulls peak wattage every time it kicks on and will run a battery down fairly quickly if the ambient temp is really hot and the thermostat causes the fridge to kick on and off. I was not using my vehicle battery (the inverter blew fuses every time) and the battery I was running it off of was not charging while I was using it. Hope that makes sense. If your battery is charging from your vehicle, you might not have the problem I had while traveling.
I did have some success with turning the thermostat down as cold as it would go, which brought it down to icy, before I traveled, then turning it back up. It kept it from cutting on and off for a while.
kwaggs
Post by kwaggs on Dec 16, 2013 18:21:55 GMT -8
SusieQ did you mean the one you have from Advanced Auto was twice that much money or half that price? Im all about stock piling parts that I will use in the future for the camper so I thought that I would buy this one and save it for when the time comes to figure out the wiring.
Post by SusieQ on Dec 16, 2013 18:28:06 GMT -8
SusieQ did you mean the one you have from Advanced Auto was twice that much money or half that price? Im all about stock piling parts that I will use in the future for the camper so I thought that I would buy this one and save it for when the time comes to figure out the wiring. Sorry, that did sound ambiguous. Adavanced Auto's is more expensive, a little over $200 but the brand does hold up and has good reviews. Keep in mind that neither of these inverters are pure sine, I believe they are modified sine (check that out for yourself.) IMHO, HF's would be worth the chance if it has good reviews.
kwaggs
Post by kwaggs on Dec 16, 2013 18:38:49 GMT -8
Thanks SusieQ! I think Im going to get myself a christmas present!
Post by vikx on Dec 16, 2013 22:56:12 GMT -8
Also be aware that the more stuff you try to run on the inverter, the bigger battery bank you will need. One small fridge might work, but anything with a fan or heating element will eat a single battery for lunch.
It has been my experience that you get what you pay for with electronics. Have fun shopping!
kwaggs
Post by kwaggs on Dec 17, 2013 17:24:24 GMT -8
Thanks for the input Vikx, what brand/type of inverter do you run and do you have a battery charging suggestion to go along with a specific size inverter? Just trying to learn about electronics in these trailers and figure out what I need to have before I get to that stage!
Post by vikx on Dec 17, 2013 21:09:52 GMT -8
To be honest, I don't have an inverter at all.
Here's the way my trailers are set up:
1. The 110 system includes the original circuit (usually only one 15 amp) and is upgraded to 30 amps, including 10/2 wire from inlet to breaker box. I usually add two more circuits, a 15 amp and a 20 amp. (extra outlets-the 20amp comes in handy for kitchen appliances) The original lights are kept and rebuilt.
2. A new 12 volt system is installed. This includes the fuse block, a Fantastic Fan, a cigar plug, a water pump and multiple 12 volt lights. I use a deep cycle 24 series battery on the tongue to power the 12 volt system. It is charged thru the 7 way cord when driving and by a small battery maintainer when plugged into shore power.
Very simple and works well. One can boon dock for 3 days if careful. Some folks use a small solar panel for an extra boost to the battery. (they don't do much unless you have lots of sunlight and even then, provide a slow trickle charge)
As mentioned above, to run appliances, you need a battery BANK instead of a single battery. 6 volt golf cart batteries work well but are expensive. Why not go with the original vintage trailer system and add 12 volt? Most of our trailers were designed to boon dock and do it well. The hand pump provided sink water, the gas light illumination and cooking was done on the stove. Many had a "passive" wall heater (no power required)The 12 volt systems allows for the water pump, charging cell phones and adds lighting. An ice chest works well for keeping food and drinks cold. Another option is a propane refrigerator but they are very spendy. A propane fridge will often run two weeks on a single 20lb tank...
Of course you can add lots of electronics but that's not what I do. Keep it simple.
Post by SusieQ on Dec 17, 2013 22:08:55 GMT -8
Vikx that is a perfect set up and what I want to do with my Shasta, except I'll add a quick connect for my solar panels. I too, get three days off of a deep cycle but my present trailer is not wired for 12v thus the inverter. That is running a fan, sometimes TV, laptops, a string of LED lights outside and charging my phone. My trailer and main tow vehicle is set up with a flat four pin connection, not a seven so I have 80w solar panels that I charge the battery with during the day when I have sun. With continuous sun, it will keep the battery charged. If the battery gets depleted (bad thing to do, and I've done it) the solar panels will not completely charge it. I carry a small charger for charging when I'm not boon docking. My deep cycle battery (ok, I stole it from my husband's boat), has an awesome case which has two 12v plugs. I have used the 250 watt inverter from my car, plugged it into the battery case and powered all of the above when I was boondocked. I had blownd up a brand new 1500w inverter and had to come up with something else. It worked just fine. So for low voltage stuff, 2000w is overkill. For my fridge, I have a separate gel cell battery and I kept them both in my tow vehicle for use while I was on the road. I plan on a battery bank for my Shasta ($$ ching, ching) but I will use gel cells and put them in the trailer rather than on the tongue. And I haven't known anyone yet with any kind of electric heater that doesn't drain a battery in a very short period of time, so you better have a really big bank and bank roll for that!!! I do know people with 12v ARB refrigerators and they are low voltage and work great but pricey: www.amazon.com/ARB-10800352-Fridge-Freezer-Quart/dp/B004P9C032/ref=sr_1_1?ie=UTF8&qid=1387346778&sr=8-1&keywords=arb+fridge+freezerSorry if this is posted somewhere else, but I ran across this site about banking batteries a couple of years ago and it is great simple info: www.batterystuff.com/kb/articles/battery-articles/battery-bank-tutorial.html
Post by bigbill on Dec 18, 2013 18:10:56 GMT -8
My suggestion is go to HFs website bring up the inverter and read the customer reviews they will tell you what you have to do to make it work. You will discover the difference caused by using the wrong gauge wire.
Post by cowcharge on Dec 19, 2013 23:56:53 GMT -8
"6 volt golf cart batteries work well but are expensive."
I got two, 230ah, 6-volt golf cart batteries at Sam's Club for $220. I love 'em. While one 75ah AGM Group 24 battery is $142, has a third of the capacity of mine, and it's not deep cycle, it's a starting battery. If a battery is rated in cold cranking amps it ain't deep cycle, and won't last like it should in a camper, not in regular use at least. Might be fine if you only camp twice a year and don't discharge it deeply, but starting batteries are just not made for repeated deep discharges.
The thing you have to watch with inverters is that they need 9 amps DC out of your battery to make one amp of AC. So one 60-watt bulb that takes half an amp AC (60w/120v=.5a) takes 4.5 amps out of your battery. A 75ah group 24 "marine" battery (which is NOT a deep cycle battery, whatever the sales literature says) will reach 50% discharge (maximum recommended for long battery life) in about 7 hours running just that one light bulb. Not that you should run AC lights from an inverter when 12v LED lights save so much electricity... My 900-watt coffee maker would take 7.5 amps AC (900a/120v=7.5a), but 67.5 amps DC out of your battery! The Group 24 battery would hit 50% discharged in 33 minutes. Not good if you want to do anything besides drink coffee...
To figure out how large a battery bank you need, you must:
Take the amp usage of every appliance and light (from the data plates, if in watts divide by the voltage) and multiple each by the projected amount of time you will use each per day, to get the total amp-hours for that appliance per day. For example, if you run the above-mentioned 900-watt coffee maker for an hour per day, it would require 7.5 amp-hours AC per day.
Multiply all AC-through-inverter appliances by 9 to get the amp-hours DC they need out of your battery. Coffee maker jumps up to 67.5 ah/day @ 1 hour usage.
Add all the appliances' daily subtotals all together to get your total amp-hour needs per day.
Multiply by the maximum number of days you want to be able to go without charging, sit down in case you faint, then double it (to keep your batteries above 50% charged). That's the size battery bank you need.
Also, using too large an inverter for a small load costs you, in increased losses in the inverter. One man I respect uses a small cheap car-type inverter (300 watts or so) to run the small stuff like phone chargers and laptops, and saves the big inverter for stuff like power tools, sewing machine, coffee maker and microwave. I have a 1000-watt inverter that runs my TV/antenna, computer, shop vac, and corded drill for a weekend without any issues so far (along with a hot air furnace running 24/7 and 12v lights and boom box). I haven't bought a fridge yet, so I have no data there.
I charge with a 210-watt house solar panel (big flat-roofed '76 Shasta 2250 with 2.5-inch rafters), which keeps things charged in the summer and between winter weekends no problem (again, no fridge yet), but would not allow full-timing without another charging source. I'll probably add another panel when I can afford it (tax refund will most likely go for another panel and a new charge controller).
And as Bill mentioned, wire size, if too small or two long, will ruin every attempt you make to be energy efficient. I used 4 gauge from battery to inverter and solar charger to battery, and they are both less than six feet long.
That cooler looks pretty nice. It has a compressor, which means it's a "real" fridge and not one of those almost-useless thermoelectric coolers. It says it takes up to 2.3 amps DC. If you can afford the $700, you could run it for about 16 hours on a Group 24 battery, or about 50 hours on my golf cart batteries...
pathfinder3081
1971 Shasta Loflyte
Post by pathfinder3081 on Dec 20, 2013 18:54:08 GMT -8
I am a little bit of a light weight I guess.. Give us party lights, a microwave for 10 or 20 minutes on a three day weekend gig..Mmm?..ENOUGH. (I have about $400 in my rig) What do you really need ? (lol) I am running a DP31 with a super charger.. I have yet to run out of juice. If I do?.. I'll let you know.. (smile) I'll go to a multi-battery pack later.... I am sure that the Frigde would be the boom!.. nice cooled products.. SWEET. I can't get there yet. An iced cooler still works here. I just don't want to go into the camper every time I want something from the cooler (lol).. jeepers! Think about it... Others here can give you tons of feed back on batteries, generators,solar, windpower.... JUICE!.. I say, start small and simple... This 1000 watt Converter will run run a dorm Micro or a Toaster, and while it struggles with our electric coffee pot.. so what! Perk and cook the brew on gas or outside on the campfire.. (perked cofffee is cool!) Heat kills Batteries and when you plan it out.. you can do with out it or work around it.. LIGHTS! Illumination, that is the true prize in my world... And then the radio, the CD player.. I still have the Ice crusher from the Island, The laptop charger..then??? Yeah, having power in the field in really cool. But shoot small, miss small. Start small and move from there.
kwaggs
Post by kwaggs on Dec 21, 2013 2:38:13 GMT -8
Thanks for all the input Cowcharge and Pathfinder! I have quite a ways to go before I get to the electrical part of my build but I am trying to learn and absorb as much as I can about the different electrical systems that I could install in our camper. I actually just finished welding up and painting my new wheel wells and hopefully will be installing the new floor this weekend! Once that is in then it is on to sanding the coat closet and refinishing that. I really appreciate your input with the inverter and my motto has always been since cub scouts, be prepared, and so I want to be sure that I am OVER powered rather than underpowered. I want to be sure that if my amazing wife wants to pull out the griddle and make pancakes, hashbrowns, scrambled eggs, and bacon that she has enough power to do it even 5 days into a trip! So I need to do my homework and every little bit helps!
Post by cowcharge on Dec 23, 2013 7:45:50 GMT -8
Well I admit I'm going overboard on my electrical system, 'cause I want to be able to full-time in it and maintain a 21st Century lifestyle (in other words, use as much electricity as I want like a spoiled American, even though I don't drink coffee or have to dry my hair LOL). Got no barn to put it in, so I've been doing everything backwards and inside out compared to everyone else. I've been using the camper since I bought it as I fix it up, and doing most of the work inside it and camping in it at the same time. It's been parked on a farm with no hookups of any kind for two years now. Right now I don't have a camper, I have a wheeled workshop with amenities. All this spaghetti will be neatly mounted on a panel after the insulation and paneling go in, and I got new fuse blocks for all the small 12v wiring to put in also. This is the port bow, where the street side dinette seat will be. I have the same converter as you Pathfinder (mine's the 9245), but I haven't used it since the solar panel went on.
kwaggs
Post by kwaggs on Mar 15, 2014 17:57:51 GMT -8
Cowcharge I have been working on the camper as much as possible and I am coming up on wiring it soon. If I went with 6v golf cart batteries can I use the same wiring as with a 12v deep cycle? I dont know what to do as far as batteries to choose from.
