ekimnamniets
Post by ekimnamniets on Sept 17, 2019 12:11:56 GMT -8
Hey all, this '55 Traveleze I've purchased is in major need of structural help. No, it wasn't a surprise (I'm a glutton for punishment). I know I have to lift the skins. There is so much info on here so to save some browsing time......what is the correct order for tear down? Front and rear skins then roof? Do skins and framing happen before anything is done inside? As usual, all help is appreciated!
Post by vikx on Sept 17, 2019 20:16:39 GMT -8
ekimnamniets
Post by ekimnamniets on Sept 18, 2019 5:56:15 GMT -8
Thanks vikx, I'm sure it is a great read and would have a world of usable info......but you lost me at "E-book/download". I'm pretty old school and prefer my reading material to be printed format. It's hard to lie down in bed and snuggle up with my P.C. monitor. I guess I'm still waiting for a reply with usable info.
oakback
Post by oakback on Sept 18, 2019 9:38:20 GMT -8
Most of these trailers (all?) are built from the inside-out. If you start to disassemble yours, everything becomes much more clear as you go. For instance, if you remove your j-rail (or corner molding) on the exterior, you'll either see that the top/wrap (front/roof/back) skin either overlaps the side skins, or they stop short at the corner (mine were like this). Whether or not they overlap would dictate what order you remove skins. From what I've seen on this forum, most wrap skins overlap the side skins, so you'd have to remove that first.
Before I started mine I read a lot and posted a bunch of questions, but once I started removing things (carefully, methodically) it was like a "duh" moment. There aren't a bunch of well-kept secrets, everything is there for you to see once you start working on it, and it's pretty evident.
ekimnamniets
Post by ekimnamniets on Sept 18, 2019 11:11:22 GMT -8
Gottcha. I'll be pulling the j-rail first opportunity. Thanks for the input.
Post by mobiltec on Sept 18, 2019 16:05:50 GMT -8
I'll tout myself as well LOL... Shameless plug. www.cannedhamtrailers.comLot's of videos on everything you'll need to know. Welcome to our world.
ekimnamniets
Post by ekimnamniets on Sept 18, 2019 16:44:25 GMT -8
Thanks mobiletech! Lots of great content.
ekimnamniets
Post by ekimnamniets on Sept 18, 2019 16:45:44 GMT -8
Guess that should have been mobiletec! Might as well get it correct.
Post by mobiltec on Sept 19, 2019 10:09:06 GMT -8
Guess that should have been mobiletec! Might as well get it correct. Only one e... MOBILTEC
ekimnamniets
Post by ekimnamniets on Sept 19, 2019 10:26:55 GMT -8
I'm going to save that vowel....in case I ever get on "Wheel of Fortune".
