Shan Delee
1963 Century
Post by Shan Delee on Sept 16, 2019 6:40:38 GMT -8
I am getting the roof off of my "1963 Century Travel Trailer" and am having trouble removing this vent. I have taken out all of the twisty nails holding it down and loosened the goop underneath. There were also 2 screws holding the outer pipe to the inner. I've also stuck a screw driver in between the inner and outer pipes and loosened it. It will wiggle and feels like it should lift off but won't. I don't want to cut it off in the hopes that I can reuse the heater. Does anyone know if there are some other screws that I am not seeing or some other way it is attached? THANK YOU!
<a data-flickr-embed="true" href="https://www.flickr.com/photos/157438297@N03/48734343606/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/48734343606_25c1990612_z.jpg" width="640" height="480" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/157438297@N03/48734526922/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/48734526922_c41547a8af_z.jpg" width="480" height="640" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/157438297@N03/48734008923/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/48734008923_4e28caf0d5_z.jpg" width="480" height="640" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Post by mobiltec on Sept 19, 2019 13:13:53 GMT -8
The metal pieces have most likely corroded together. The vent tubes are not that expensive. I would just give it up and tear it out and replace it. But if you want to continue to try to separate the pieces it just takes a lot of banging and struggling and cussing and holding your mouth right...
Post by Ten on Sept 19, 2019 21:45:12 GMT -8
^^^ Amen....
