kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Aug 5, 2019 18:48:15 GMT -8
How best to affix this metal piece? I put putty behind the screw holes, and even with just a little, the whole thing doesn't sit flat on the skins. Thoughts? Thanks!!! IMG_7530 by kathy, on Flickr
Post by kirkadie on Aug 6, 2019 4:36:59 GMT -8
Scotty's emblems were simply screwed to the skin originally. That was probably 'water-tight enough' back when trailer was built. You might just force some putty into the screw holes before attaching, not the big blobs you have in the picture and see if the emblem lies flat.
Post by vikx on Aug 7, 2019 19:42:32 GMT -8
Add a dab of OSI gutter seal to the screw holes and screw flush to the skin. No putty.
chriss
Post by chriss on Aug 9, 2019 19:17:46 GMT -8
It helps too if you can back it with wood. Most emblems and lights were originally screwed into the siding. If you take off skin, put wood where any lights and emblems screw to. Helps to compress the putty. You can also put putty between some wax paper and use a roller to thin it out.
aslmx
Post by aslmx on Aug 13, 2019 17:46:48 GMT -8
I’m with vikx. Gutter seal , no putty
Post by mobiltec on Aug 17, 2019 16:44:33 GMT -8
Add a dab of OSI gutter seal to the screw holes and screw flush to the skin. No putty. Thanks Vikx I never thought of that.
Post by vikx on Aug 17, 2019 19:14:29 GMT -8
Putty makes 'em stick out funny...
