Alaska Shasta
1964 Shasta
Post by Alaska Shasta on Aug 4, 2019 13:01:36 GMT -8
I am going to put the Central hand pump back into service on my 64 Shasta. Since all the pieces are in great shape, all I will need to replace are the two o-rings. The NAPA part numbers for the o-rings are 727-2210 and 727-2116. Here is an exploded view of the individual pieces.
185C823F-0FFF-4105-900F-EB2ED944798C by Bryan Port, on Flickr Here is the silicone grease and o-rings needed. 30FDF90D-5EBA-417B-9162-46E35BE6E27C by Bryan Port, on Flickr Install the large o-ring onto the bottom of the inner plunger, and lubricate it with the silicone. Also, lubricate the plunger shaft. 5E00FD11-20DA-4801-807D-7F14DCFB641E by Bryan Port, on Flickr Insert the plunger through the faucet housing. FEF7117B-A85C-4A9E-A804-4C1C7398BF7C by Bryan Port, on Flickr Lubricate and install the small o-ring and knurled nut onto the upper plunger, and tighten the nut. 6AEA7430-66D7-4849-8985-33D3C4BB74A1 by Bryan Port, on Flickr There is a small convex cap that goes on the end of the plunger before the handle goes on. Put it into position now. 100FA8BE-F2F6-48D4-A6BA-973A2E8DD82D by Bryan Port, on Flickr Insert a screwdriver through the hole in the base of the plunger, thread the handle on, and hold the screwdriver while you thighten the chrome handle. FF039942-D6C6-4476-B40C-00683DCC74DF by Bryan Port, on Flickr Insert the metal check ball into the brass outer housing, and push the inner plunger into the outer housing. F1330C33-11EF-4344-8E12-DC5AE3F1CB75 by Bryan Port, on Flickr Screw the brass housing into the base of the chrome faucet. 51A02B6E-315D-488F-B38F-CA0E22216E43 by Bryan Port, on Flickr At this point it is back together and functional. Test by putting the bottom of the base into a container of water, and cycle the plunger up and down. It will squirt water as you go both up and down. 😀 F7A790AB-E8D5-426E-BB7C-BB88F76C1D4D by Bryan Port, on Flickr
Alaska Shasta
1964 Shasta
Post by Alaska Shasta on Aug 5, 2019 17:55:59 GMT -8
Photos and instructions added. Cheers
Post by vikx on Aug 5, 2019 21:12:56 GMT -8
Also, some of these old pumps had leather gaskets. Harder to replicate and repair. Thanks so much for adding to this!
