violamomof4
1954 Jewel
Post by violamomof4 on Jul 17, 2019 13:48:41 GMT -8
Got the paint off my icebox and looked great and we rinsed it and within five minutes it started to rust before our eyes! There wasn’t ANY rust on it when we got original paint off!!! So odd. We dried it quickly and got some mineral oil on it to help stop it from rusting. NOW WHAT DO I DO??? Help! 😳😳😳
Post by mobiltec on Jul 17, 2019 14:16:07 GMT -8
The inside should never be painted because the paint just flakes off over time and clogs up the drain tube. If the galvanization is coming off then you have another problem. I don't really know what to do about that.
Anyone???
Alaska Shasta
1964 Shasta
Post by Alaska Shasta on Jul 17, 2019 16:25:04 GMT -8
Got the paint off my icebox and looked great and we rinsed it and within five minutes it started to rust before our eyes! There wasn’t ANY rust on it when we got original paint off!!! So odd. We dried it quickly and got some mineral oil on it to help stop it from rusting. NOW WHAT DO I DO??? Help! 😳😳😳 These are suggestions for the exterior surface only. Steel will surface rust almost immediately. Sand it with say 320 grit sandpaper. Then you will need to clean the surface, and prime it prior to painting. At NAPA you can get # 7234 prep clean, and # 7220 direct to metal primer, both in aerosol. You do not need to sand the 7220 primer prior to paint, if you paint it within 24 hours. Hope this helps, I have been in the coatings industry 40 years.
Post by danrhodes on Jul 17, 2019 17:47:56 GMT -8
I'd clean it really well, especially with the mineral oil on it and use a rustoleum primer. A bit of advice that stuck with me about these old painted things, that paint lasted for decades and is likely better adhered than any primer you can get today. Rather than stripping to bare metal, clean and scuff then paint over the original paint. I put tractor paint right over my old paint without primer and it's held up well.
violamomof4
1954 Jewel
Post by violamomof4 on Jul 17, 2019 18:00:22 GMT -8
The interior was already painted. Interesting. THANK YOU! So I should leave the interior just blank, correct?
violamomof4
1954 Jewel
Post by violamomof4 on Jul 17, 2019 18:03:13 GMT -8
The inside should never be painted because the paint just flakes off over time and clogs up the drain tube. If the galvanization is coming off then you have another problem. I don't really know what to do about that. Anyone??? Thank you so much for your help!
MayBell
1959 DeVille
Post by MayBell on Jul 18, 2019 9:49:22 GMT -8
violamomof4
1954 Jewel
Post by violamomof4 on Jul 20, 2019 9:49:44 GMT -8
So I followed your advice with the #7234 and7220 and then painting with rusteeze and when I started painting I guess my finger was too large for the nozzle and was hanging over and caused the paint to drip! 😳🙄UGH!!! So mad. As my husband says, give it that homey feel! I’m hoping the second coat covers it up! The same thing happened when I was working with the primer but I had gloves on. I took the gloves off after that thinking I’d fixed the problem! Not! Hoping it’s a glossier finish that it currently looks. Says gloss finish on can. Doesn’t look to shiny. Hmmm
Post by vikx on Jul 22, 2019 20:28:04 GMT -8
If it doesn't shine up, try Rustoleum hammered silver. It has a really nice finish and is easy to paint/touch up. Of course it is hammered looking, but I like it.
Post by Teachndad on Jul 23, 2019 5:55:03 GMT -8
Hi Friends, I might be late to the party on this one, but powdercoating can be an alternative. It's much much more expensive than a $6 can of paint, though. Very durable, though. Might be worth a phone call for estimates - or not. Cheers, Rod
azshastanut
1957 Kenskill 16T
Post by azshastanut on Jul 23, 2019 9:24:22 GMT -8
If you want high gloss, you can coat it with clear wheel rattle can spray. It will cover up a multitude of mistakes.
violamomof4
1954 Jewel
Post by violamomof4 on Jul 25, 2019 7:39:09 GMT -8
So I painted several coats of paint on icebox door and every time there’d be 2-4 spots that would collect debris like a magnet!!! I’d wet sand it down with 1000 grit and it still would look horrid. But I think I’ve finally figured it out!!!👍🏼👍🏼 Can says spray 12-18” away from whatever you’re painting....BUT Due to our low humidity...that doesn’t work. Paint is drying too quickly. I tried 6”....still too far away. So I just tried 3”! That’s CLOSE! It’s a fine line between 3” and dripping!!! Im praying this last coat will be IT!!! Fingers crossed!!! I also went a different direction with the paint... Will c!
violamomof4
1954 Jewel
Post by violamomof4 on Jul 25, 2019 17:00:51 GMT -8
I was so excited! Icebox door was looking good....then the gloss coat went on and began to run in 3 different spots!!! NOOOOO!!!! 😩😩😩😩I’m praying if I sand it tomorrow wirh 800-1000 grit and respray it that it won’t show! Fingers crossed 🤞
