Post by utahroadrunner on Apr 8, 2019 17:56:02 GMT -8
IMG_3646 2 by Ben Rod, on Flickr Rusted C channel frame. I can grind the outside, but what to do on the inside of the frame? Would you just clean it out and POR-15 the inside/outside?
Post by vikx on Apr 8, 2019 19:51:55 GMT -8
You could wire brush the inside or most of it. Clean as well as you can, especially the loose debris. POR-15 instructions should tell about covering rust. Should be fine.
Post by utahroadrunner on Apr 8, 2019 20:18:52 GMT -8
You could wire brush the inside or most of it. Clean as well as you can, especially the loose debris. POR-15 instructions should tell about covering rust. Should be fine. Thanks Vikx. BTW purchased your book last week. Wonderful information and very helpful.
Post by nccamper on Apr 9, 2019 4:38:55 GMT -8
POR-15 is the best but this has also worked for me: It's great if the frame is a little rough because it leaves a texture. It's also a one coat (step) product.
jeremiah
Post by jeremiah on Apr 9, 2019 5:25:12 GMT -8
Rust never sleeps
Post by utahroadrunner on Apr 9, 2019 9:07:19 GMT -8
How much would you recommend for a standard trailer frame?
Post by nccamper on Apr 9, 2019 16:39:41 GMT -8
I think 3 quarts covered the frame of my last Shasta. I used it on a Forester about 4 years ago and it's holding up well.
ozmo
Peeling a fresh 59 Airflyte today.
Shasta airflyte
Post by ozmo on Apr 10, 2019 17:26:23 GMT -8
Nonsense you fools!LOL Sanding...hmmmm. Nope, sent mine to the sandblasters and then powder coater. Came home today (-: DSCN2744 by David Siepker, on Flickr
