Post by tincantraveler on Apr 3, 2019 8:42:31 GMT -8
Hi, tincantraveler here. Does anyone have knowledge of the wheel assembly on the Aristocrat Land Commander or where I mightf find out about the wheel assembly? I’m stuck in Ohio. Apparently the new tires I bought were not tight enough and the lug nuts broke off with the wheel. The mechanic shop I was towed to is really busy so I’m doing leg work to facilitate a faster recovery of my Art.
Thank you
Post by vikx on Apr 3, 2019 20:30:07 GMT -8
Many trailers used Ford passenger rims with a 5 on 4 1/2 lug pattern. Not exactly sure what you're asking, but the shop should be able to tell you what you need... and maybe order them for you. If it truly is a 1954, the wheels could be very different. You may be looking at a new axle or?
Post by tincantraveler on Apr 4, 2019 10:23:56 GMT -8
Thank you . I’m still on the lookout for a better rim but we are mobile. Appreciate your time.
