Post by youngbloodhawk on Mar 18, 2019 15:36:07 GMT -8
It’s time to get one or a like unit. Older reviews here are all good but those reviews are several years old. Amazon reviews are mostly good but a good number of folks are very negative on quality,a higher percentage of poor reviews than I’m comfortable with for a toilet that now costs $150 ish. Are still happy with your Curve. Not a subject I want problems with at midnight!
PT
Post by PT on Mar 18, 2019 18:30:17 GMT -8
I"m thinking of getting one too... Most of the negative reviews on Amazon have to do with the failure of the battery powered water pump for the flush mechanism used on the US version. I looked on UK Amazon and you can purchase the hand pump version of the flush mechanism to have as a backup and they will ship to the US. An extra expense but an option to consider.
Post by turbodaddy on Mar 19, 2019 4:01:00 GMT -8
Ours is now 5 years old, and works fine. Easy to empty, doesn't stink, easy to clean. I use the old black water holding tank for gray water now. Same capacity (about 13 gallons) as the fresh water tank, so when the FW runs out, it is time to empty holding tank. There are 3 of us, and we can go about 3 days without emptying it when boondocking, obviously longer when using campground facilities and roadside restrooms. I think that since it so simplifies plumbing issues it is worth $150.
Post by youngbloodhawk on Mar 20, 2019 4:32:49 GMT -8
Thank you
Post by bigbill on Mar 20, 2019 17:02:13 GMT -8
It is taller with a deeper bowl which a lot of guys will like.
