kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jan 19, 2019 16:09:33 GMT -8
See the long piece of wood directly under the front window? (Not the one below where the table connects). Is there a purpose for this piece? Just wondering- I am replacing- but just curious. Thanks Kathy IMG_0159 by kathy, on Flickr
Post by nccamper on Jan 19, 2019 17:55:10 GMT -8
My understanding is that piece works with the framing behind it to firm up the area being hit with 60mph winds. It also firms up the wall that the table is putting pressure on.
Shasta also put a metal support (attached to the framing behind this piece) to firm it up even more. The dark area on top of the framing:
kathleenc
Post by kathleenc on Jan 19, 2019 18:17:24 GMT -8
I'm having to rebuild the entire front of my Shasta 1500, without any template. Can you share pictures of what the framing is supposed to look like, including the metal support? Thanks!
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jan 19, 2019 19:49:34 GMT -8
I'm having to rebuild the entire front of my Shasta 1500, without any template. Can you share pictures of what the framing is supposed to look like, including the metal support? Thanks! I unfortunately cant find any photos of original front framing before I ripped it out- but this is one as I was finishing the front. I have not added the metal support- but do have it here to add. I need to add a frame piece to back up the wood that holds the table too. Hope this helps a little- I am sure others will chime in with more experience. K IMG_4742 by kathy, on Flickr
Post by Ten on Jan 19, 2019 22:00:33 GMT -8
nccamper is correct, this piece along with the metal strip piece inside the wall is there to give lateral strength to the wall, against wind and other stress. It helps keep that big long window from being popped out of its framework,or breaking the putty seal around it.
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jan 20, 2019 10:34:28 GMT -8
nccamper is correct, this piece along with the metal strip piece inside the wall is there to give lateral strength to the wall, against wind and other stress. It helps keep that big long window from being popped out of its framework,or breaking the putty seal around it. Can I add the metal piece to the bottom of the framing piece under my window? Obviously I cant add it to the top- as it would interfere with the window placement. This makes sense to me- as the piece inside is right under the window. I just never took a picture of it I guess- glad I asked ! I guess the other option is to add another frame member under the one that is there- if the metal needs to be on top of that board?? Thanks K IMG_4742 by kathy, on Flickr
Post by nccamper on Jan 20, 2019 14:42:04 GMT -8
Basically, you can add framing under the window anyplace you want as long as you place one piece to screw in the (inside) support board you asked about. The metal support piece can be bought at any Lowe's or Home Depot. It goes on the framing piece supporting the inside piece. Together these piece really beef up the front wall. Original framing on a 1963 Shasta 1500: Repaired framing:
kathleenc
Post by kathleenc on Jan 20, 2019 16:25:57 GMT -8
Thanks! What kind of metal is it? This is extremely helpful. I stopped working on the trailer because I was just lost as to the framing for the front. (Front was already demolished when I bought it years ago)
Post by Ten on Jan 20, 2019 22:52:18 GMT -8
Just to clarify one point... The metal strip is attached to the second frame member down, not to the window framework itself. The frame at this point supports the table-hanging mount. The longer wood piece that's the subject of the original question is attached inside to the frame member at the bottom of the window. These two items work to stiffen the width of the front of the trailer.
The metal piece is just a strip of steel, about 1/8 or 3/16 thick, width less than the frame member, screw holes in three or four places...it's been a while since I have had my hands on it. If it is missing, you may want to consider a strip of aluminum instead of the steel, so as to avoid the problem of dissimilar metals.
Post by Teachndad on Jan 21, 2019 5:58:14 GMT -8
Hi Friends,
Interesting topic. I knew what the wood piece was for , but fascinating to learn about the strip of metal on the inside of the wall. I am curious. Those of you folks who have seen the metal strip, was it rusted or are they painted before installation to stop any developing rust?
Thanks,
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jan 21, 2019 8:22:46 GMT -8
Just to clarify one point... Thank you!! I am so glad I asked !! K
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jan 21, 2019 9:28:43 GMT -8
So- I found a photo of the front framing before ripping it out. Here it is: IMG_0682 by kathy, on Flickr And here's what it looks like now: IMG_4742 by kathy, on Flickr Looks like I will be adding another framing member- with metal piece- at the point where table support is inside. Thanks so much for all this info everyone- really makes sense ! Love this place !! ha ha
Post by nccamper on Jan 21, 2019 11:20:53 GMT -8
It looks like this but it's 3/4" wide 5 or 6 feet long. Drill holes about every 7 or 8" apart.
Post by Teachndad on Jan 22, 2019 9:37:56 GMT -8
Hi Friends,
So, is it optimum to screw this piece of steel into the cross member before you mount the cross member into the framework? Seems like clearance for your drill bit and Philips drive bit would be limited after installing the wood cross member.
windborn
1957 Sportcraft 15
Post by windborn on Jan 22, 2019 13:41:26 GMT -8
I've been kicking myself for years for not installing a small shelf under my window for knick-knacks. Wish I had seen this before my rebuild (and known that it would help with support.) I assume this is something that should be added during the build? Or has anyone added or replaced a shelf with their skins already on?
