drg
Post by drg on Jan 17, 2019 17:45:13 GMT -8
Hello,
Does anyone know if Aljoa is pronounced with a "hard j" or a "soft j" ?
Hope that makes sense.
Gustave
Post by vikx on Jan 17, 2019 20:55:07 GMT -8
It's Al Joe ah. Or, in older trailers, Aljo
drg
Post by drg on Jan 17, 2019 21:33:36 GMT -8
It's Al Joe ah. Or, in older trailers, Aljo Excellent. Thank you.
Post by mobiltec on Jan 18, 2019 22:07:11 GMT -8
It's Al Joe ah. Or, in older trailers, Aljo Excellent. Thank you. Looks like what you have there is an Aljoa if it is a 1954 or earlier. 1954 is the year they dropped the "a" due to a law suit brought against them by Alcoa Aluminum claiming infringement on their trade mark. So the company became Aljo...
drg
Post by drg on Jan 19, 2019 20:04:42 GMT -8
Looks like what you have there is an Aljoa if it is a 1954 or earlier. 1954 is the year they dropped the "a" due to a law suit brought against them by Alcoa Aluminum claiming infringement on their trade mark. So the company became Aljo... Interesting. It was sold as a 1955. But it has a plaque on it that says Aljoa, built in Gardena. The plaque might not be original (I'll take a pic of it when I get home in a day or two). Is there a way to trace the year from the VIN on the frame? Gustave
Post by vikx on Jan 19, 2019 21:14:48 GMT -8
Post your VIN and I'll try. I think mine was coded for length, width and serial number.
6150072958= 56 (the 6) 15 feet 00" long, 7' wide, serial #2958. Oddly the number was on the A frame coupler piece witch usually isn't done since it can be changed out.
Post by mobiltec on Jan 20, 2019 7:38:50 GMT -8
Looks like what you have there is an Aljoa if it is a 1954 or earlier. 1954 is the year they dropped the "a" due to a law suit brought against them by Alcoa Aluminum claiming infringement on their trade mark. So the company became Aljo... Interesting. It was sold as a 1955. But it has a plaque on it that says Aljoa, built in Gardena. The plaque might not be original (I'll take a pic of it when I get home in a day or two). Is there a way to trace the year from the VIN on the frame? Gustave Interesting that you caught that. See they still had a lot of plaques sitting around in the shop and they wanted to use them up. So they continued with the plaques that said ALJOA on them until they ran out while painting the emblems that had no "A"...
drg
Post by drg on Jan 20, 2019 11:13:54 GMT -8
The "VIN" on the pink slip is 54131288.
There is a number stamped on the front portion of the frame (tongue). I have not yet checked to see if they match. I just stumbled on it as I was examining the jack the other day.
Post by mobiltec on Jan 20, 2019 13:04:19 GMT -8
The "VIN" on the pink slip is 54131288. There is a number stamped on the front portion of the frame (tongue). I have not yet checked to see if they match. I just stumbled on it as I was examining the jack the other day. In this case, the trailer vin shows the year of manufacture (54). Is your trailer 13 feet long? If so it shows the length and the number off the line was number 1288 also but this isn't always the case. These things vary from manufacturer to manufacturer.
drg
Post by drg on Jan 20, 2019 15:20:46 GMT -8
The "VIN" on the pink slip is 54131288. There is a number stamped on the front portion of the frame (tongue). I have not yet checked to see if they match. I just stumbled on it as I was examining the jack the other day. In this case, the trailer vin shows the year of manufacture (54). Is your trailer 13 feet long? If so it shows the length and the number off the line was number 1288 also but this isn't always the case. These things vary from manufacturer to manufacturer. Ah, interesting. Maybe I have a '54. How is the length of a camper measured exactly? Is it the total length of the "shadow" it projects on the ground? Gustave
Post by mobiltec on Jan 20, 2019 17:05:12 GMT -8
In this case, the trailer vin shows the year of manufacture (54). Is your trailer 13 feet long? If so it shows the length and the number off the line was number 1288 also but this isn't always the case. These things vary from manufacturer to manufacturer. Ah, interesting. Maybe I have a '54. How is the length of a camper measured exactly? Is it the total length of the "shadow" it projects on the ground? Gustave The way we measure them today is total length from tongue to bumper. But Aljoa could have been just measuring the box for the VIN. How long is yours?
drg
Post by drg on Jan 20, 2019 17:45:07 GMT -8
Ah, interesting. Maybe I have a '54. How is the length of a camper measured exactly? Is it the total length of the "shadow" it projects on the ground? Gustave The way we measure them today is total length from tongue to bumper. But Aljoa could have been just measuring the box for the VIN. How long is yours? I am out of town at the moment. Will measure it in a couple of days and report back. Gustave
drg
Post by drg on Jan 22, 2019 14:19:33 GMT -8
OK, as promised, here is a pic of the ID # And here is a pic of the plaques affixed to the camper, just to the right of the door, mid-height: Since these plaques are just screwed onto the camper, they could have come from anywhere I suppose. I'm under no impression that they are original. I measured the camper length and it is 13 ft long from tongue to stern. The "ham" portion is only 11 ft long. So, is this a 1955 or a 1954? Gustave
Post by mobiltec on Jan 22, 2019 17:16:17 GMT -8
It's a 54 but may have not been registered for the first time until 55. And when you paint it I would go with ALJOA... The lawsuit didn't actually end until 57 so they may have gone on painting ALJOA on them until then. And I am sure that your plaques are original.
drg
Post by drg on Jan 22, 2019 17:39:49 GMT -8
OK, thank you. I guess I will refer to it as a '54 Aljoa then. Gustave
