Post by Teachndad on Jan 17, 2019 22:52:51 GMT -8
In the past I cut the nails holding the curving/layered edge board with a multi-tool but on the latest Shasta I used the saws-all with a metal cutting blade. I was surprised how fast it moved without destroying the birch panels.
I use the cheaper blades now to cut out windows/etc. As said above, even the most expensive blades don't last long on nails. I bought a very highly rated $17 blade and it lasted (maybe) three times longer on nails than the $2.50 cheap metal cutting blade.
Hi NC, Did you use a smaller s awsall like what vikx recommends or the big one I use for cutting tree branches sometimes. I just can't picture using the big one for cutting paneling from the wooden framing behind it. Seems sort of over kill and risks destruction. Thanks, Rod
Post by nccamper on Jan 18, 2019 6:32:08 GMT -8
I used the full size saws-all. Once the blade is between the birch panel and the curving/edge board it's easy to control. At times I cut in the middle of the curving, cutting the nails below the heads. From that point the curving basically pops off.
I once tried cutting out windows with the saws-all and it chipped the birch.
