Post by nccamper on Dec 17, 2018 16:56:31 GMT -8
What brand of AC unit is this a picture of? The black one:
Not sure of the white one.
HOTRODPRIMER
1957 Shasta
Post by HOTRODPRIMER on Dec 17, 2018 20:06:45 GMT -8
The white one in my photo is a Soleus heat/air/dehumidifer 8000 BTU unit. Danny
Post by Teachndad on Dec 18, 2018 22:15:14 GMT -8
Hey Danny,
How did you mount your a/c heater unit in the closet, or is it moved in and out of the camper every time you use it?
Thanks
HOTRODPRIMER
1957 Shasta
Post by HOTRODPRIMER on Dec 19, 2018 7:45:20 GMT -8
Hey Danny, How did you mount your a/c heater unit in the closet, or is it moved in and out of the camper every time you use it? Thanks Rod Rod, it is permanently mounted in the closet, the air/heat is vented through the front of the door and the return is in the side of the cabinet. The drain hose is routed through the floor as is the exhaust via a flexible hose and vent.Danny
Post by Teachndad on Dec 19, 2018 12:07:44 GMT -8
Thanks Danny,
It's a clean look for sure. I was also interested in the specific mounting technique you used. Did the unit have mounting holes in it or did you have/make brackets?
Thanks.
HOTRODPRIMER
1957 Shasta
Post by HOTRODPRIMER on Dec 20, 2018 13:20:08 GMT -8
The wheels were removed and a simple flat bracket was bolted to the floor of the closet. Danny
Getnold
1957 Westerner Pony Express
Post by Getnold on Oct 27, 2019 19:23:19 GMT -8
Hello Danny, It's been a while since you posted this but I am thinking of doing this in my camper. Do you like how it worked out? Anything you'd change about how you installed the unit or anything else? Do you have photos of the vent and drain tube through the floor? What vent cover did you use on the bottom of the trailer? Thx!
Post by nccamper on Oct 28, 2019 4:09:51 GMT -8
The wheels were removed and a simple flat bracket was bolted to the floor of the closet. Danny Getnold, If you "quote" his post a notice will be emailed to him. You'll have a better chance of getting a response on an older post by a member who only checks in from time to time.
Post by danrhodes on Oct 28, 2019 6:06:13 GMT -8
