Post by southernpride on Oct 26, 2018 16:46:54 GMT -8
Thank you for adding me to this Group. Please explain the meaning behind S11514. These are the only numbers I can find on this older Shasta camper. Once stamped on the tongue and on a small welded tag on the inside of the tongue. Thanks in advance.
Post by Ten on Oct 26, 2018 18:25:35 GMT -8
The number would be the VIN for your trailer. The placements you describe are correct placement for Shasta VIN numbers. Each plant had separate numberings, and each had a letter to denote the plant. The "S" character denotes that the trailer was manufactured in the South Carolina plant, the rest is a sequential number. The numbers did not represent any particular information such as model or year built. The year can be narrowed down by comparing to a long accumulated list of the VINs.
