jodybitzz
1968 Shasta 1500
Post by jodybitzz on Jul 11, 2014 7:00:35 GMT -8
Absolutely gorgeous! Your title says this is a 68. It looks no later than a 64 with the real wood and the ham rather than toaster shape. And the stove turned out beautifully. What you are doing is a prime example of what we all mean when we talk about the time and money spent on our little trailers. 5 hours on a stove. If I had had to pay for that, I probably would have left it alone! Thank you so much Hamlet! This has definitely turned out to be more work than we had ever thought but we are all enjoying the process. We will be attempting to hang the new skin this weekend.... Yikes!
Post by vikx on Jul 11, 2014 21:00:29 GMT -8
Congrats on doing the job right!
jodybitzz
1968 Shasta 1500
Post by jodybitzz on Jul 12, 2014 17:59:10 GMT -8
So the skin went ok today. We did have one dumbass mistake; when cutting out for the baggage door, we cut the opening square instead of with a radius thus making the hole too big. Hopefully we can remedy this either by making a washer or buying a larger door. We also learned that when using a router to clean the edges, it is best to put masking tape around the perimeter of the opening and also on the base plate of the router. Of course we learned this after we had some small scratches on the skin. Overall, a very productive day. All four pieces up on both sides. Tomorrow we will tackle the roof and the front and back.
Post by SusieQ on Jul 12, 2014 19:10:50 GMT -8
It looks FABULOUS!!!! Jody, you'll come up with a "fix" for the baggage door and it won't seem so awful to you then. I've really enjoyed watching your progress!
Post by vikx on Jul 12, 2014 21:08:47 GMT -8
Jody, I would change to a square baggage door, since the corners are already square. You can get them custom made and/or buy a used one. Do you still have the old doors and frames?
And don't feel bad, everyday I make a mistake.
jodybitzz
1968 Shasta 1500
Post by jodybitzz on Jul 13, 2014 4:08:23 GMT -8
Jody, I would change to a square baggage door, since the corners are already square. You can get them custom made and/or buy a used one. Do you still have the old doors and frames? And don't feel bad, everyday I make a mistake. Vikx, do you know where I can order doors? We do not have the old ones because there never were any. Lol. We added a baggage door to each side to make it easier for storage.
Post by vikx on Jul 13, 2014 9:18:44 GMT -8
Interstate metals makes them: interstatervmetalandsupply.com/cat_compdoors.html Also All-Rite but they are very expensive... Check around your area, there may be a local company willing to build you a pair. The square corner solution will look much more vintage anyway. Let us know what you find.
jodybitzz
1968 Shasta 1500
Post by jodybitzz on Jul 13, 2014 18:16:07 GMT -8
jodybitzz
1968 Shasta 1500
Post by jodybitzz on Jul 14, 2014 10:35:11 GMT -8
Interstate metals makes them: interstatervmetalandsupply.com/cat_compdoors.html Also All-Rite but they are very expensive... Check around your area, there may be a local company willing to build you a pair. The square corner solution will look much more vintage anyway. Let us know what you find. So far Interstate is quoting around $140 per door and All Rite is $250. Per door. Yikes!!
jodybitzz
1968 Shasta 1500
Post by jodybitzz on Jul 14, 2014 11:59:14 GMT -8
Post by SusieQ on Jul 14, 2014 17:24:27 GMT -8
Hope that works out for you. We might need to add this one to the link section.
Post by vikx on Jul 14, 2014 21:34:57 GMT -8
YAY!!
jodybitzz
1968 Shasta 1500
Post by jodybitzz on Jul 20, 2014 11:43:27 GMT -8
First ceiling panels now in.
Post by Hamlet on Jul 20, 2014 14:15:04 GMT -8
It just keeps looking better and better. Keep the pics coming!
jodybitzz
1968 Shasta 1500
Post by jodybitzz on Jul 28, 2014 16:36:34 GMT -8
New square baggage doors came in from www.challengerdoor.com. Very impressed with the product and their packaging/shipping. Finished the back wall with the birch today as well!
